HomerRulez
- Apr 17, 2005
I will be buying the following item and would like to know if it will outperform m RZ 40C1B VAIO? If so by how much? Also whats with the new 64bit CPUs by Intel? They any good? Better then a northwood? I would appreciate and and all help and thank you in advance!
CPU Intel P4 630 64bit 3.0Ghz 800Mhz FSB 2Mb L2 90nm
Motherboard ABIT Fatal1ty AA8XE With µGuru Clock
RAM 1GB Corsair TWINX XMS2 5400 4-4-4-12 Latency Dual Channel DDR2
HeatSink Thermaltake Beetle Proformance Cooler Heatpipe
System HDD RAID 200GB Maxtor SATA II 7200 RPM 8Mb Cache NCQ
Optical Drive Plextor PX-716SA SATA 16x DVD-RW Black
Second Optical Drive NEC 3520A Dual Layer16x DVD +/- RW Black
Floppy Drive/IO Mitsumi Floppy 7 in 1 Card reader Black Compact Flash, MicroDrive, MemoryStick,SmartMedia, MultiMedia, or Secure Digital Cards and Floppy
Video SAPPHIRE Radeon X850 XT 256MB GDDR3, 256-Bit, Dual DVI, VIVO
Audio Intel High Definition 7.1 Audio Codec with separate sound card riser
PSU OCZ ModStream 520 Watt Modular Power Supply
Case Coolermaster CAVALIER 1 Black With Window
OS Windows XP Pro OEM
Warranty 3 Years repair/replacement for all parts.
