Not sure if this should really be here or anywhere but I figured this would be the place to get an answer. I was just wondering if it was possible to use a water pump to pump air. I basically just need to pump air from 1 tube to another for a small project but the only pumps I can find marketed as air pumps have 1 "port" for a tube/hose to go as output whereas water pumps for water cooling have 2 tube/hose "ports" since they are designed to recycle the liquid.
I (obviously?) don't know anything about pumps so go easy on me hehe.
To mods: If this is better suited somewhere else, please move this. Or if not suited at all, please remove the thread (although I would love a PM or something just to let me know it was deleted.)
Thanks~
Thanks~
