I have a Koolance 4870X2 GPU water block. It has an acrylic window on it that developed a very small crack and began a slow leak.
I sent the block to Koolance for repair. And it took them a while to get the part, but that has now have it fixed and they sent me this message:
"The acrylic appears to have been damaged both by a third party chemical and excessive heat. Please be sure to use only authorized liquids and do not run with poor liquid circulation."
I'm going to dismiss the heat, because my GPU temps were always very good (40 to 55C) and I have periodically checked the GPU block temp by feel and it was always relatively cool to the touch. I do not believe heat was an issue.
I also believe my water flow was pretty good. I use an MCP655 set on 5. And from the good temps and visual water flow appearance in the reservoir, I don't believe this to have been an issue.
So I'm just left to the only liquid additive I used. PT Nuke. I put 2 drops in after a fresh build. Which I thought might have been a little on the light side since it says 1 to 2 drops per liter (think I might have 2 liters of water in there).
And I use distilled water by the way. Should I stop using PT Nuke? Use less? Use something else? I'm not concerned about clouding because I have colored water tubes, so I wouldn't see it anyway.
Or do we think this just might be a generic explanation for the failure and I shouldn't worry about it?
