It's yet to be seen if installing OSX on non-Apple hardware is illegal to begin with. I'm not sure how it would be, it's certainly not copyright infringement. Since the only 'law' that can make companies liable for making 'enabling' tools is the DMCA, and that relies on copyright infringment being the act enabled, I'm wondering too.
does the EULA from apple say i agree to install this OS only on an Apple branded machine? guess i gotta go digging through my paperwork to find out
Even if it does, it's far from a sure thing. Courts are divided on whether EULAs are binding or not, and reverse-engineering is protected and lawful, especially for interoperability. Personally I think it's ridiculous, and I'm hoping the courts would uphold that. It's like putting a chip in your car that would only let you drive on Apple roads using Apple gasoline and then making it illegal to circumvent.
are they pretty much charging for something that you can get for free?
what you just said sounds a whole lot like napster arguement, cassette tapes, and DVDxCOPY. 'just because we made the means of doing this nasty shit, doesn't mean they will....'
they are the head shop, OSX is the weed.
If you do this do you still technically have a hackintosh? I mean what's the difference between this and an osx86 distro that works flawlessly with your hardware? Just legality?
I really doubt they're going to be writing drivers, but it wouldn't surprise me if they'll help you get hardware going that should work (ie. has a supported chipset etc.) but has issues that can be solved with configuration tweaks/DSDT/etc.so if you're willing to part with hardware for them to make drivers for it, you get that too....it's a little....iffy, BUT that's better support than i've seen for this type of service. and i wonder if say you sent in a gpu that didn't work, if they'd offer that driver to other users, or just you.
Yeah I have a GTX 260 and I can't find any drivers for it. People say they will work but without 3d acceleration.
Would be interesting to see. because it could imply that if you dont buy the $500 memory upgrade when you buy your Apple and instead buy the $100 memory from Newegg and install it, are you violating the EULA? Same with putting in a new harddrive that doesn't say Apple on it.
ALSO (from their website):
"To alleviate some the incompatibility issues some devices will experience, Psystar has begun their home certification program. Once authenticated, users will be given the opportunity to send in hardware components that are not working correctly and have our engineers build a profile for the device."
