I figured with all these "is my psu enough" threads, I'd throw one in slightly different.
I have:
EVGA 680i
Q6600 @ 3.6Ghz
4x1Gb ddr1066
4x320gb SATA drives
1xPATA DVD/RW
GTX260 @ 756/1200
8800GTS640 @ 700/1000
X-Fi Titanium Pro PCI-E
OCZ GameXtreme 600w
Here's the issue I'm running into. I used to have good voltages on 3.3v, 5v, and 12v. Almost spot on and steady. Now that I've upgraded to a GTX260, and have left the 8800GTS640 in and dedicated it to physx (which obviously isn't utilized all the time), I've noticed my voltages are no longer steady, and are below/above the standard ratings. 3.3v is now 3.18v, 5v is now 4.8v, and 12v is now 12.45v.
Since I had left the older GTS in, I was planning on upgrading in the near future anyway, but should I expedite that upgrade? I was thinking of the Thermaltake Toughpower 750w, or Hiper 880w. I wanted some room to expand with - so would the 750w cover the components now with room to grow in the future?
I have:
EVGA 680i
Q6600 @ 3.6Ghz
4x1Gb ddr1066
4x320gb SATA drives
1xPATA DVD/RW
GTX260 @ 756/1200
OCZ GameXtreme 600w
