Jelic said:X-Connect power supplies are way too big, stay away from them, if you want to fit a normal sized optical drive then you NEED right angle molex connectors.. otherwise i'd suggest getting a Lite-On optical drive with an Enermax Liberty 400w power supply. It has 20a on both 12v rails so it should be plenty for whatever you throw in a ssf, plus it's a little shorter than normal power supplies.
