Alacrity Fitzhugh
- May 1, 2006
Looking to put a 600W power supply in my X-QPACK2 case. I'd like it modular, have 2 PCIx connectors, and 4 SATA. Don't want to spend too much money. Any recommendations?
I'm looking to upgrade my video card to one of the newer Geforce GTX 260s, and they state the *minimum* power supply required is 500W, so I figured I'd pad it a little. Plus, these cards need two 6-pin power supply connections, and the PS I have only has one.
Nah. That's BS. They say this sort of stuff for people with very low quality PSUs (ie low Amps relatively on the 12V rail). But for good quality PSUs, like Silverstone, Corsair and Enermax, 450W is plenty for a single 260. I run a 260 (640MHz) with a E8400 clocked at 3.6GHz (though undervolted) and worst case scenario I hit 310W at the wall, which, assuming 85% efficiency, is about 265W DC. And that's an unrealistic worst-case scenario (Furmark + Prime95). Gaming I'm at least 30W lower. So 500W is plenty (I overspec'ed my PSU: it's a 525W Modu82+ from Enermax. I should have gone for a 425W).
While true, do note that the XQPack does come with the shitty PSU you speak of: It IS an Apevia. So the OP will need a new PSU no matter what.
