PSU recommendation
Not sure what PSU to use on this PC build.
Did you already buy the X2 6400+? If not, ditch it. The X2 7750 outperforms the X2 6400+ and only costs $65:
AMD Athlon64 X2 7750 CPU - $65
And if you're planning on overclocking, ditch the 790FX mobo. Try to find a mobo using the SB750 southbridge like the 790GX.
Oh and we definitely need a budget range for the PSU. But this is one of the best bang for the buck PSUs out now:
PC Power & Cooling S75CF 750W PSU - $90
yeah, I already bought the 6400. around 150 bucks max for PSU. don't plan on OC'ing it
Might as well just grab the one Danny suggested then. It's a great PSU for a great price, and you're unlikely to find a better deal.
