PSU question
Discussion in 'Power Supplies' started by fightingfi, Feb 7, 2019.
  1. fightingfi
    fightingfi Look at Me! I need the attention.
    2,391
    Oct 9, 2008
    Looking at seasonic 850w for a build\upgrade
    whats the difference in the gold, plat, and tit series besides the price?
  2. tedych
    tedych Limp Gawd
    260
    Jan 18, 2013
    If you talk about 80 Plus efficiency ratings... it's moot.
    Efficiency is what energy is lost inside the PSU itself when working. Gold may have 90% at given % load, Platinum may have 91% etc. Finally, the differences in you electricity bill would be so negligible that it just plain doesn't matter IF you don't use your PSU/computer at maximum load 24/7.
    It just matters if it's at least Bronze and not just 80 Plus - there the difference is usually not so negligible. But Bronze and up... not really.
    Being Silver or Gold or Platinum doesn't imply anything about the quality of the PSU at least for what it's worth - quality outputs, regulation of voltage, protections etc.
  3. fightingfi
    2,391
    Oct 9, 2008
  4. pitingres
    pitingres n00b
    47
    Jul 25, 2018
    Efficiency at various loads. Look up "80 Plus" on wikipedia.
    "tedych" was I think trying to say that you don't buy higher efficiency models because you expect to save money over the long run, because you won't. You buy Platinum or Titanium either because a) you're trying to minimize heat output, and perhaps fan noise, or b) you just like the idea of having a super efficient power supply in your rig.
  5. CAD4466HK
    CAD4466HK Gawd
    932
    Jul 24, 2008
  6. fightingfi
    2,391
    Oct 9, 2008
    soooooooooooo which one do i buy...............?
  7. Susquehannock
    Susquehannock 2[H]4U
    3,108
    Jul 26, 2005
    This one ;)
  8. Tsumi
    Tsumi [H]ardForum Junkie
    12,861
    Mar 18, 2010
    There are differences in voltage regulation, noise suppression, components used, and warranty. Go look up reviews of the particular lines you are looking at, and decide what is important to you. [H]OCP and Jonnyguru are two of the best PSU reviewers.
  9. dragonstongue
    dragonstongue 2[H]4U
    2,991
    Nov 18, 2008
    I am quite partial to Seasonic (old) version of the 550-850 watt that have SSRxxxRM as their model number, mainly because they "give you" the extra cpu power connector where their newer Focus line (to the best of my knowledge) got rid of such, yes it is only for "overclocking" but it is nice to have it there and all.
    I have the 650-G (SSR650-RM) very nice unit, handles itself well, legacy be damned, it is a solid unit, the 550 and the others in this lineup specifically all test very well, as well as being priced fairly does not hurt anything either.
    I forget the original question, but in terms of quality based on bronze vs silver is it worth to pay more etc etc.
    IMHO
    Silver (not see many)
    Gold
    Are absolutely worth the extra cost from a reputed maker, 550-650 range is ample for most builds and a decent quality gold semi to full modular PSU is ~$150 shipped unless you want extra pretty fancy RGB crud or super crazy top end wattge.
  10. fightingfi
    2,391
    Oct 9, 2008
    did hardocp review this one? are you REALLY serious>
  11. Susquehannock
    3,108
    Jul 26, 2005
    Not that I am aware of. Though do seem to remember Jonnyguru did a review. Cannot find it. Not top shelf quality but decent. And with the rebate it may be one of the best bang for the buck units in the 850w range. Know you are looking at Seasonic but figured I'd throw it out there.
  12. CAD4466HK
    CAD4466HK Gawd
    932
    Jul 24, 2008
    Tazz has been redoing JonnyGURU site format since OW left, a lot of the more recent reviews are not back up yet.
    Susquehannock likes this.
  13. Paul_Johnson
    Paul_Johnson [H] PSU Editor & Admin Staff Member
    15,252
    Aug 29, 2004
    No, I didn't review it. We are on EVGA's do not sample list and it never seemed compelling enough to buy to review.
  14. JRZoid
    JRZoid n00b
    22
    Feb 1, 2019
    It's Probably ok to Good....My older 750w CoolerMaster GXii Pro...is something a little nicer going on. That IS Dual Rubycon front and Rubycon/Chemicon Secondary...it's Fine and Strong still. I would expect no less.
    With Today's Systems a good 750w is Plenty in Reality.
  15. primetime
    primetime [H]ardness Supreme
    5,414
    Aug 17, 2005
    same one i bought at bestbuy and currently use
  16. horrorshow
    horrorshow [H]ardness Supreme
    5,923
    Dec 14, 2007
    Nioce. I just convinced my brother to pick up the 750w version a couple days ago.
  17. highlander2607
    highlander2607 [H]Lite
    71
    Jan 14, 2006
    I bought the Seasonic Titanium 1000W at Christmas for a I9 9900K build. It is silent and has performed well but there has been a strange smell coming out of it since day one. Voltages are good and everything checks out ok but the smell is still there after 1 month. Not as strong as before but still enough to notice. There were a few posts I found about this and most were that some Seasonic's would do this during break in but would quit later on. I hope this is the case.
