PSU Jumping... Am I doing this right?
Nims
My PC turned off the other day and would not turn back on. I thought it was the Power Supply so I tried to Jumpstart the PSU. Below is a picture of how I placed the paperclip. When I tried the old PSU, it didn't work so I figured it was a bad supply. So I bought a new one and installed it only to have it not turn on the PC either. I'm getting absolutely nothing out of the PC once I hit the power switch, no attempt at booting or anything. I've tried Jumpstarting both PSU and they are not working. My question is am I not doing it correctly? I've hooked up 3 fans to the PSU when attempting to power it on but it did not work. Also, when I have it plugged into the Mobo, the blue led on the mobo comes on but nothing happens. If it is not the PSU, could it be the vid card?
Sorry about the pic, was taken with phone.
my.php
you need to put the paper clip in the hole of the 24 pin connecter.
You put one end in the hole representing the green wire, and and other whole with a black wire.
and presto it should turn on.
Also, it still could be your motherboard, or cpu, or ram.....good luck!
That's what I did though. Put the paperclip into the the slot where the green wire is and where the black wire is and it didn't power on. Tried it with two different Power Supplies one of them being right out of the box.
Some PSU's will not power on without a load of some sort. Put a couple of fans on it.
Tried putting fans on it also. Going to go pick up a tester later and try that....
Turned out to be two bad psu's. My original one and the one I ended up buying. Worked great after exchanging it. Thanks for the tips...
