PSU/Harddrive/Maybe Mobo issues
Hi there, my thread is to do with the PSU, Mobo and HDD, but I believe it's mainly PSU related. I warn you in advance this thread is really, really long because i felt it necessary to explain everything. So yeah, please help.....
Ok well, it all started a few weeks ago. First my fan on my motherboard started what can only be described as high-pitched squealing and dropping from 6000RPM to 4000RPM (which, although stopped the screaming, was NOT good for the motherboard). It had done this a few times before in the past though and fortunately my dad and I knew how to solve it. We took out the fan, cleared out the dust and re-greased it.
The one thing that hadn't happened before with my screaming fan (this is also prior to fixing it) however was my computer freezing mid-use. It wouldn't matter what i was doing, whether gaming or just on the desktop. At first I attributed this freezing to the screaming fan. I have now, however, re-evaluated my idea as to whats causing it.
You see, when my computer froze i went to restart it, the problem is when it did, it would not detect the harddrive. To fix this, i first had to turn off my computer, then turn off the power supply, wait a couple of seconds, turn the PSU back on, wait a few more seconds/minutes (sometimes i had to leave it for 20 minutes or so) so it would boot up properly and detect the HDD and boot into windows.
So far it looks like the HDD is the culprit right? Well, heres a few more "issues" that arose when the fan was screaming. First of all, the computer would struggle to boot. I'm not even kidding, i could shut down the computer, come back a couple minutes later (or hours/first thing in the morning etc.) to turn it back on for it to just sit their like a car with the handbrake on, so I'd go around to the back of the PC, switch off the PSU, wait a few beats, turn it back on, wait a couple more, then switch it on. Sometimes it'd switch back on, other times not and others it would sit there, then after a few moments the fans would whirr slightly and start making sparking noises. (The first time this happened I knew it couldn't possibly be a good sign so I ran around to the back and shut the PSU off faster than you can say "OMFGTHISPOSTISSOLONGLOL" :p )
Although a pain at first, i put up with this, just gritting my teeth and getting on with it. After my dad and I sorted the Motherboard fan the problems stopped. Everything was perfect and was going swimmingly well. The computer would boot, wouldn't even make the slightest squeal at 6kRPM, the harddrive would always be detected. Life was good. :)
Then a few days later disaster struck, my computer now struggles to boot at all, and when it does it rarely ever detects the HDD. In fact, just the other day it did detect the HDD and although it POST'd (is that the right word?) perfectly fine when it came to the point where it says "Detecting IDE drives.....", after it detected the HDD (which is SATA btw) it stopped there and didn't move any further (not even to "Verifying DMI data"). So i then turned off the computer, tried to turn it back on and hit the same problem. So i had to turn the PSU on and off again and to get the computer to boot again, which resulted in the HDD to not be detected again.
(Also, I've tried switching the slot the HDD is in to no avail. Oh and another thing, before my system completely died it did have a couple of errors when it reached the DMI pool data booting stage of the PC.)
I haven't bothered to try to boot since.
I built my PC myself 2 years ago and has only had a few problems in the past but nothing ever on the scale of this.
I bought all my parts for my PC (sans graphics card) at this site: http://www.planetmicro.co.uk.
Here's my specs:
AMD 3000+ 64 1.8 GHz Sck939
Foxconn WinFast NF4UK8AA-8EKRS Motherboard
1GB DDR400 RAM
550W PSU (Cheap generic PSU similar to this http://www.planetmicro.co.uk/product_info.asp?stockcode=M002673)
Maxtor 160GB 7200RPM SATA Harddrive (It was cheap and i think it was a Maxtor - I'll check properly later)
Nvidia Geforce 6800(vanilla) PCI-Express 325/600 clocks(standard)
Creative X-fi Xtreme Gamer Soundcard
Not sure you need to know anything else such as my monitor etc.
Heres my ideas as to what might have happened:
The PSU is faulty and is the cause of the problems I've been having. The PSU has either caused the Motherboard to fail to detect the HDD every time i boot the computer now or the PSU has created bad sectors in the HDD which now causes it to fail to be detected.
Please help me. I really don't know what to do anymore... :(
Voice.
P.S. Sorry about the long post, but i really felt it was necessary to explain everything.
Oh and if theres any spelling mistakes i apologise. Just try to guess what I meant to say.
EDIT:
Overheating: My CPU is always sitting around 30-35C which I'm pretty certain isn't a dangerous temp.
Another thing i forgot to mention was that sometimes (this is occuring more often) when "Detecing IDE drives...." kicks in it sometimes hangs when trying to detect my harddrive and then skips past it with "none", it's as if it knows its there but can't quite see it.
My completely uneducated guess would be your CPU possibly. A way to check your PSU would be to borrow one from another computer you have at the house, and if the power rating is lower just unplug some of your devices.
My reasons for guessing the CPU are the boot-up problems. I remember I had my CPU running hot for about a year (it always ran hot and I think it was faulty to begin with). I would get freezes in games and sometimes in windows. Then if you tried to reboot right away it would hang on startup.
I guess the easy thing to do is if you can swap in the PSU you can eliminate that as a problem. If it persists it may be your CPU or your HD causing the problem (though I don't think its the HD because of the previous Windows hangs don't seem to point to that). If it's your CPU or your MB it doesn't really matter because you will most likely need to replace both.
I also don't think it's your HD because sometime it doesn't even make it to HD detect, and sometimes it does, and sometimes it passes. There seems to be a lack of a consistent boot failure.
My guess is an overheated CPU tooks it toll and eventually became damaged.
For the record I don't want to confuse you....
Your best bet is to start swapping things out and see what makes it work.
Swap PSU, swap in another SATA hard-drive and see where that gets you.
Thats actually one of the things i meant to put in about but forgot to. The reason being is that my CPU is always sitting around 30-35C which I'm pretty certain isn't a dangerous temp. Another thing i forgot to mention was that sometimes (this is occuring more often) when "Detecing IDE drives...." kicks in it sometimes hangs when trying to detect my harddrive and then skips past it with "none", it's as if it knows its there but can't quite see it.
I'll add this to the main post. Thanks for your input. :)
Although I'd like to do that unfortunately all the other computers in my house are before SATA. I'll see about the PSU though, although I wouldn't want to blow my dads computer up, but i'll definately look into it, thanks. :)
Wel... since Foxconn makes pretty much all the motherboards for Dell... and we know how long those last in general...
I've actually seen a few that had bad chipsets that would transfer data super slow to and from the hdd.
As for it being a cheapo power supply, I would get a good one first and test with that as a power supply is more apt to cause really weird issues.
And for the hard drive detecting issue.. provided it isn't the power supply - I would try a different known good cable.
And last but not least.. try clearing the BIOS. Sometimes the BIOS settings can get corrupted and cause all kinds of funky issues.
Start there and buy something decent.
Yeah. I'm definitely going to get a new PSU.
A little while earlier i tried out one of my relatives PSUs on my computer. Booted up like a dream, however, the PSU was somewhat old and did not have a SATA port for my HDD so I'm going to have to look a bit further into that.
Thanks for your input everybody!
Voice.
EDIT: Oh and you probably ought to know that the PSU i used to test my PC on was a 350W PSU made by Dragon Technologies Ltd. I tried Dragon's website but they have moved on into the medical field i believe. So then i decided to type in the PSUs code into Google and up popped the exact same PSU but made by QMax. (QMax is on the list of PSU's not recommended) So even though the PSU isn't from a good brand, it still booted my computer fine. (I will, however, be getting a good PSU and not spending the bare minimum on it.) Oh and I believe the PSU was made in 2003.
Just got a sata cable to connect my HDD and temp-PSU. It was somewhat of a struggle at first, (i.e. didn't boot up straight away) but now my computer boots fine (so far) although i have heard clicking noises from the HDD which I'm fairly certain isn't a good sign.
For my new PSU I want something that can not only "do the job", but also something thats fairly future proof, since i plan to upgrade my computer sometime soon. Currently I've been looking at:
Corsair HX 620W
http://www.overclockers.co.uk/showproduct.php?prodid=CA-004-CS
And the
OCZ GameXStream 600w Silent
http://www.overclockers.co.uk/showproduct.php?prodid=CA-018-OC&tool=3
But I'm not entirely sure about what to get.
Here's my current system:
1GB DDR400 RAM
But I also want something that'll last for future upgrades such as the Penryn/Phenom CPU, ATI 3900/Nvidia 9800, 2GB RAM etc. That sort of thing.
If anyone has any suggestions feel free to put them forward.
thanks,
Voice.
