PSU for Quad Core build
Vertago
So here's my build.
CPU: Intel Quad-core Q9550
MB: ASUS P5Q Pro
RAM: CORSAIR DOMINATOR 4GB (2 x 2GB) DDR2 1066
Vid Card: SAPPHIRE Radeon HD 4870 1GB
HDs: Probably 3 HDs, One 1 TB, and Two 300's in RAID 0
Fans: Case came with 1 120mm on the back and I may add another
The case I got was the Antec Sonata III that came with a Antec 500w Earthwatt PSU. (Got it on Newegg on sale for $45. Case/PSU) So my question is, would that 500w support my build? And If not what should I get? If the 500 doesnt do, I was thinkin this.
The EA500D should be enough for that build. Just don't add any more hard drives than the ones you listed.
Biggest problem is that RAM: It's horribly horribly overpriced. I recommend getting this set:
G.Skill F2-8500 CL5D-4GBPK 2 x 2GB DDR2 1066 RAM - $60
Other than that, looks good to me. Definitely add another 120mm fan on that hard drive cage. It'll help cool the drives as well as the video card.
should be good but id search for a better deal on a higher wattage one so u dont have to do it later on :)
