faugusztin
- Mar 9, 2008
Hi,
i'm having problems what PSU to use/buy for my low power system. Configuration is this :
Gigabyte GA-M85M-US2H (GeForce 8200 chipset)
AMD Sempron 140
2GB DDR2-800 RAM
4xWD10EADS (1TB), 1xSamsung HD154UI (1,5TB)
Corsair HX520
Now the question is what PSU to use ? The idle power usage of this system is 69W at wall (counting with 80% efficiency it means 55.2W power usage, about 15W of that should be the power usage of disks).
55.2W seems like a perfect number for picoPSU, but there is a problem - spinup power usage. picoPSU 150 can handle only 8A sustained and 10A peak power usage, which means drives itself will take 4x 1.6A (WD drives) + 1x 2A (Samsung) = 8.4A. So picoPSU is a no-go. Next options are the bottom models of different PSU brands - but Enermax and Corsair drives has a minimum of 425-450W for modular PSU, which is way bellow the minimal 25% power for 80Plus rating (15.3-16,2%). Then there is a option of nonmodular 350W OEM Seasonic (19%), 380W Seasonic S12-II (18%), 385W Enermax Pro82 (18%) 400W Corsair CX400 (17.25%) - still too powerfull for this setup.
The last option is a superexpensive Silverstone SST-ST30NF-GM, which is a passive PSU with a price comparable to the new Seasonic X 650.
What is your opinion ? Should i stick with my current PSU which is used just because i had it as a spare, or should i buy something else (if yes, what) ?
PS: unfortunately two Enermax Modu82-425 failed on me (one had a noisy fan, other one had a electric buzz comming out of PSU even when turned off), so i'm not really interested in Enermax if there are other options
AMD Sempron 140
2GB DDR2-800 RAM
Corsair HX520
