PSU for a 2P folder
bump
If I don't set this thing to folding pretty soon after I get the jealous mob in the DC subforum will have my nuts
From everything I can read about this, it looks like the main thing you need is a PSU that meets at least EPS12V 2.91 specs. That should give you the 8+4 12V connectors that you are looking for.
Here's a post from JohnnyGuru that covers this (at the very bottom): http://www.jonnyguru.com/modules.php?name=NDFAQs&op=FAQ_Question&ndfaq_id=18
That leaves you lots of options (e.g. Corsair, Seasonic, etc.) so long has they have that listed in their specs. From even more poking around, some companies like PC Power and Cooling say that the extra 4-pin is only required on their 700W and above PSUs, so that may be a target that you want to go for. I also noticed that a person could zoom in on the power connector pictures at places like Newegg and see that the 8+4 connectors on many models.
This link has the Seasonic X650/750/850 Gold data sheet. As you can see from the bottom, it has both an 8-pin EPS connector and a 4+4 EPS power connector: http://www.seasonic.com/pdf/datasheet/NEW/Retail/X-650-750-850.pdf
Yeah, full 12 pin EPS, that is what I need
I was hoping for some guidance on good deals, usually Danny and company are all over it in here.
