soberspine
- Jul 9, 2010
Hi,
After I bought a nexus psu with coil noise that i could hear it from across the room now I got Seasonic x-660.
I don't know if I am just unlucky but the new psu makes a buzzing noise and some high pitch noise. it is not as loud as the one from nexus, but i can still hear it from inside the case. My pc have only one fan for the cpu.
My question is:
Can the coil noise in the PSU be induced/provoked by another component?
like the the motherboard. I started the pc without the video card and hdd and still can hear coil noise but not that loud, I don't have another motherboard or pc to try the psu with it.
It is just odd this in my second psu that I try and both had coil noise. I am 100% the noise is from the PSU because I mounted it outside the pc case so I can put my ear near it.
Thank you, sorry for the bad english.
My question is:
