My Rig is:
AMD Phenom II x4 920 Processor (200MHz x 14.0 @ 1.2V)
ASUS M2N-E SLi Deluxe
2x 1GB Kingston DDR2 667 Unganged Dual Channel
Maxtor 250GB SATA Hard Drive 7200RPM
XFX 8800GTX XXX Edition (630/1000/1345)
And PSU I have is almost a week used CoolerMaster's Extreme Power Plus 500W (Two 12V Rails @ 18A each. One for CPU only, other for peripheral)
My Question is: Since I am already pushing my power to 155W + 125W = 280W on GPU + CPU, if I overclock, will my PSU be at risk if I overclock? Also give me a gaming advice if I am playing Crysis 2 on a 17" Analog monitor, 1024x768 @ Enthusiast
P.S: I have Market filled with CoolerMaster Junk over here. The 80+ Single 12V Rail ones are pretty expensive. The other choices I had were the Expensive CM Silent Pro 650W one and the CM Extreme Power 600W one (18A on two 12V Rails each, same as 500W one).
I wanted to post my question about 8800GTX's power requirement before buying this PSU, but since I only have CM junk lying around, I considered buying the 500W one in my budget. The build is running pretty smooth uptil now with all voltages with a positive offset of 100 - 200mV
P.P.S: I am from Pakistan
