suiken_2mieu
- Apr 7, 2010
My room mate has a prebuilt that kicked the bucket. After some research I found the issue was the PSU was defective and Zapped the Mobo. I;m wondering what I should use as a replacement. Can I stick any ATX PSU in the Case and any 775 motherboard, or do I need a certain form factor. I'm trying to keep this fix under $100. The motherboard needs onboard video as she doesn't have a video card. Though if there is a very cheap card that I can keep the budget under $100 I can get her that would be better than any onboard stuff, I'll take it. She has a 1280x1024 monitor and she's also about to purchase a 1680x1050 monitor. She mostly browses youtube.
Specs: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4481564
Formfactor is a mini tower, I was thinking a MicroATX Motherboard. But I'm unsure as I cant find much on this computer.
This was NOT the original motherboard. (Whoops, I didn't even read the page)
I found this 575w PSU, but I'm unsure id this is garbage or not.
