I forgot to mention it is for a home network and I'll probably be the only one transferring large files, etc...I really only need 8 ports now but as the kids get older and more networked devices in-home I may need to expand...with our latest remodel bill I would prefer to spend $80 instead of $180 but if it makes sense to get 16 now I will...
And it looks like a good 8-port is the HP 1400-G8 and a good 16-port is the Dell 2716...anything else I should look at?
Get an eight port for now... grow down the road when you need it as prices will probably come down some more by then. As for whether or not you'll notice a difference between two eight ports instead of one sixteen on a home network - other than losing two ports to connect them, you won't.
I agree, On a home network you will not see a difference between 2 8 port's and 1 16 port. Like everyone has stated you will be just losing the ports to connect the two devices. Myself I would go with a decent 16 port switch. And really for a home network you do not even need a manged switch. Unless you want to setup VLAN's for the kids network, which is not a bad idea.I know you only need 16 ports, but here is a great choice. Layer 2 managed-
http://www.newegg.com/Product/Product.aspx?Item=N82E16833129153
For a little less- 8 Port Managed Pro Curve-
http://www.newegg.com/Product/Product.aspx?Item=N82E16833316053
That first layer 2 managed is just a 10/100 BTW.
