Hey guys, I'm getting close to building a new machine (in the $800 range) What do you guys think of this configuration?
It will primarily be used for gaming.
Here are my questions:
1. Ram - Is it better to get two sticks of 512 or a single 1 GB stick right now? My thinking is that with 2 512's you can take advantage of more FSB bandwidth, and it isn't very likely I'd ever need to move to 3-4 GB of memory on this machine (which I'm hoping will last a few years).
2. Dual Core. I'm wondering if it's worth going for Dual Core Processor now with this budget and skimping a bit on the video card. Do you think this processor could last me a few years with other upgrades around it?
Thanks in advance for any wisdom/thoughts.
-AMD Athlon 64 3400+ Venice 2.2GHz Socket 939 Processor
-DFI Lanparty UT CFX3200-DR Socket 939 ATI CrossFire Radeon Xpress 3200 ATX AMD Motherboard
-Western Digital Caviar RE WD1600YS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive
-XFX PVT71GUQL3 GeForce 7900GT 256MB GDDR3 PCI Express x16 Video Card
-CORSAIR ValueSelect 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel Kit System Memory Model VS1GBKIT400
-ARCTIC COOLING Silencer64UltraTC L 87 x 87 x 33 mm Blue LED Light Cooling Fan
-Antec LifeStyle SONATA II Piano Black Steel ATX Mid Tower Computer Case 450Watt SmartPower 2.0 ATX 12V V2.0 for AMD & Intel systems Power Supply
Microsoft Windows XP Home Sp2b 1pk w/Upgrade Coupon for Vista - OEM
ASUS Dual Panel Black and Beige ATAPI/E-IDE DVD-ROM Drive Model
