Project Vulcan
This will be my main Gaming rig that travels to about 10-12 lan parties a year. It a micro atx case theme Black and Orange,
Some of my concerns was the dual 120 radiator. it doesnt fit any where in the case. not yet any ways (dremal time). Air flow was another concern. But i finally came up with a pretty simple solution, mount the raditor on the botton and have air blowing in from the top and through teh bottom. The Mb has been staying at a pretty constant 30c on the test bench for about a month. I will aslo be adding soem arylic ilumminated panels and case feet.
I am pushed on time on this one and have about 10 days to complete before I take it to a Lan party on the 11th . So get ready for metal & plastic to fly !!!!
Part list
1 NZXT Vulcan Case
1 EVGA Micro atx Sli MB
2 EVGA GTX 280s
1 Intel Core i7-965 Extreme Edition
1 Cooler Master 1000w Slient PS
4 XIGMATEK Case Fans orange and white leds
1 DD- Stealth GTS 240 Black Ice Radiator
1 DD-Single 5 1/4" Bay Reservoir
1 DD-CPX-Pro 12V Pump
1 LG DVD rewritable.
1 Mod/Smart Supreme System Sleeving Kit - Black
1 Mod/Smart 20 Station LED Board - Base w/ 10x LEDs - Orange Base / Amber Switch / Amber LEDs
1 Logisys 4" Dual Cold Cathode Kit - UV
1 Feser One Orange coolant
1 Orange Tubing
12 3/8 by 5/8 compression fittings
1 TDX CPU block with Orange top
Update #1
Disassemble the Vulcan Case
Needed to make room for the Rad
Well My wife told me to move all this stuff to the garage
But i didnt have any benches
So i went to the lumber yard picked up some wood Saturday
and built 2 new ones
the parts started to arrive.
One awesome Custom TDX CPU block from Danger Den
Some really cool Xigmatek Fans
A little test Fit
wow that aint going to work (lol)
Time to get the dreamal out
Part list
1 NZXT Vulcan Case
2 EVGA GTX 280s
1 Orange Tubing
Update #1
A little test Fit
