Hey how is everyone doing? I am new here. So, Hello.
Well, this is the worklog of a project I am currently working on. As you can tell from the title it is going to be VERY satanic and dark in theme.
This is what it looked like before I started. You can also see the top of the case in this pic. It has a custom cut 120mm fan hole and you can also see where the handles have been cut out.
This is what it looks like in it's current state. There is still alot of work to be done to it. What is left of the Antec grill at the top will be gone this weekend and replaced by a plastic human skull. The skull wil also be molded into the bezel.
Here you can see that I have added a turbine shaft. It will have a fan installed into it.
And please keep in mind that it is still very early on in this project and things will change and of course as I progress they will certainly look better than they do right now.
This is a pic of the top after primer was applied it is just waitng to be painted.
This is a pic of when I was making sure the tubine was going to fit right before I glued it in.
These are some pics that are from the very beginning when I first started working on the front of the case.
These are of the right side panel of the case. These cuts are all going to backed by Modders Mesh. I am currently in the process of cutting out all 4 of the tribal designs. Man it takes a long time to do it.
Here is the case before I drew on the tribals.
Here is the tribal layout.
Here is one of the cut tribals. This has not been filed yet, so I know it looks jagged.
This pic is of the chassis with the tubine hole cut into it. The plan is to have the chassis powder coated a very dark purple color.
The left side of the case actually had an accident with my car and was mangled beyond repair. I was able to get another side, and it is going to have a really kickass pentagram waterjetted into the side. I was going to dremel the pentagram but I decided it would not look as good as I wanted it to, and would take forever.
I will keep you up to date as soon as I get more done. As soon as I finish a piece I will post it.
Any advice you guys can give will be greatly appreciated.
This is the front with the skull installed and semi finished. You may notice the body filler. LOL
Sorry for the crappy pics. I took them at night and they came out really bad. I will take some more tomorrow in the daylight. As you can see I have kind of a mock up of how the fan will sit in the front intake.
Here is a pic of one of the fan blades after its second coat of paint. Again I will take some better pics of this as well.
