Project: Ultra Defender
Dallas
So here is my first electronics project, which is also the first "mod" to my case. This fanbus a work in progress, I plan to add a few more things to the front panel. Right now it consists of 4 on-off-on switches with 2 LEDs per switch. Down is low (7v, 1 LED), up is high (12v, 2 LEDs). Sorry the photo's white balance is off, I am posting this on a spare computer while I wait to order new parts.
I got all of these parts from www.allelectronics.com.
First I came across a project board and decided to put it to use. I soldered some plugs for my fan connectors first.
I put a switch and LEDs on it that I had already made to make sure everything worked the way I thought it would, and it did.
Here is the board with the resistors for the LEDs and some leads for the fan connectors. Oh and the big ugly molex connector.
The bottom with all the solder joints. This is the first time I have soldered before.
Here is the drive bay that everything is going in. Originally I was going to use a 3in bay but I sure am glad I chose a 5, there is a lot more room. There is the DPDT switches and LEDs.
Here is the beginning of the mistake I made. Instead of soldering the leads to the panel then to the board, I did it the hard way. I put them on the board first, then to the front. That turned out to be a real big pain in the ass to connect the two together. If only I had stopped and thought for an extra half second..
Here it is coming together..
And here it is finished. What a mess. But it worked the first time!
And here it is in my case. Man it sure is nice to have, and it was very simple to make even for a first timer. It may not be the peatiest though but I made it! I am ordering new parts next week for my new computer and that will start round two of my modding.
