AaronP
- Jan 13, 2005
Project Tux is my personal project that I've been waiting to do for a few months now. It's already been underway and I just hadn't thought too much about taking pictures of it and etc till just now
________________________________________________________________
Task List:
Cut out hole for Acrylic Window [ Done ]
Place Drill holes for both the side panel and the acrylic [ Done ]
Put trim on the edges of the panel [ ] (I don't have any, but I just ordered some from Xoxide)
Bolt the acrylic window to the side panel [ Sorta Done ]*
Paint the Case [ PENDING ]**
Place Tox Memorabilia [ ](Tux Fan Grill, Tux Window Decal, etc)
Paint the Optical Drives [ ]
Replace Power Supply [ ]
Sleeve the wires [ ]
Replace Already Present HDD and Power LEDs [ ]
Place Cold Cathodes [ ]
Place Cold Blue LED Fan [ ]
Replace CPU HSF [ Done ]
Replace Motherboard [ ]
Purchase Low Cost Video Card [ ]
Purchase New RAM [ ]
* I mounted the window but only because I got tired of it sitting around, I'm currently waiting for the trim to arrive.
** In the pictures you will see a 1/2 ass job of painting, I didn't really take my time with it and I paid for it in the end (It cost me around $10
). I'll be sanding the actually metal part down (the front bezel is plastic) and repainting it. I also haven't painted the door yet.
Pictures of the 1/4 ass done project:
Sorry my digital camera JUST died (like it won't accept the charge of the batteries) so I'll show you it ASAP.
Parts being considered for the replacement parts:
Motherboard
512MB Stick of RAM (Keep in mind this isn't an expensive computer so the parts I pick out are very reasonable for it's overall purpose)
Power Supply
Video Card
Tux Crap I'm buying to put on/in the case:
Tux Fan GrillThis will go inside the case on the fan, no need to have a 15$ fan grill in the back
Tux Decal
Tux Case Badge
Task List:
Motherboard
Power Supply
Video Card
Tux Decal
Tux Case Badge
