Hello all,
A good friend of mine liked my 1st project, and decided that he wanted me to mod his case. He has a TT - Shark, im gonna do a simple mod, using plexi (blue and transparent), a 2x120 RadGrill and some white leds. Some photos:
Here is the plexi and the grill
At the moment the ideas for this case mod are:
* Open a hole on top to put the grill with some 120mm fans
* Paint the front and B shape on the side with some dark\marine blue
* Open a new window on the side panel and fill it with the transparent plexi and after create a shape with the blue plexi that will be lighted with leds.
* Make a "radiator holder" using blue plexi on the HDD place
* Make some holes on the side to help the cable hiding
* Get a way to draw\paste a shark shape shadow (in the plexi) on the side mesh area
* Anything else that might come to my mind while im doing the above
LOL
*NOTE* After i finish this project i got a sponsorship in form of another case that i will start right after finishing this one so you gonna hear from me more.
