DarkenReaper57
- Oct 2, 2003
About a year ago, I completed a custom external watercooling enclosure. Here is a link to the original worklog: http://www.hardforum.com/showthread.php?t=915156&highlight=external+w/c+box I was very satisfied with my work. After it has sat on top of my case and been through several moves and LAN parties, however, it has gathered dust, a few marks here and there, and doesn't glimmer as it used to. In addition, the my processor is not running as cool as it used to, and the system was never as quiet as I originally intended it to be.
I am starting this project to revitalize my overall system, but especially the external enclosure. I want to make a few changes so it looks a bit more appealing as well.
Here is the system at near completion, about a year ago:
Here is the system in its current, shall I say, dilapidated state:
With the flash off (this is more of what it really looks like) there is still some mirror-like shine to the black paint and aluminum frame, but it is not what it once was:
One of the main reasons why I seek to refinish this system is the leaking res:
The dust is pretty bad too
Not to worry, though, I have a new criticool reservoir here for a replacement. I could only find the 6" version, though. Some reorganization will be needed so it can fit.
Note that I painted the ugly brass colored barbs black. I laid down several prime coats and a nice thick color coat, so hopefully the paint will not flake. They look much better, don't you think?
To help silence this system, I will be switching out my current undervolted Panaflo U1A's for Sanyo Denki San Ace fans. I'll also switch out my current case fans for these yate loons.
I also want to change the mesh and handle assembly. I was never a huge fan of the current mesh, but it was cheap. I decided to bite the bullet and buy an AC Ryan
MeshxPanel. I like it a lot
And a preview of what it will sort-of look like on the side:
The first thing I need to do is sleeve and tail my new Sanyo Denki fans. Then I'll unrivet the top of the enclosure and proceed to redo everything. I'll probably drain the loop and clean out the heater cores well, etc. More to come soon!
P.S. Any suggestions/feedback would be greatly appreciated.
