Outamyhead
- Jan 3, 2008
Yeah that should get the ball moving, consumer mediation FTW, and subbing this project as it looks awesome.
I already have small claims pending against Fedex and Dell, as well as a grievance against Dell through the Office of the New York State Attorney General.
Well i wouldn't go so far as to say junk...Ordered my Sandy Bridge 2600K and Gigabyte GA-Z68X-UD7 to replace all the AMD junk. Hopefully I will have it by tomorrow and then I can take some snap shots and install it so I can route my tubing and start my leak tests!
Today was a good day, as I have won both my small claim suits against Fedex and Dell as they did not show up to defend themselves in my case against them. I was awarded a total of $1000, $500 from Dell and $500 from Fedex.![]()
Is that your pump fitted to the radiator? What type of bracket is holding it there?
Oh I see. Thanks.Its the Koolance mounting bracket that came with the pump top kit. I modified it slightly but cutting out a section of the plate that is flush against the radiator so my airflow does not get impeeded too much and I drilled new holes so I could mount the DDC dressed with the Koolance DDC heatsink kit.
Good God ... that is a beast of a case.
And that is one of their "small" ones ?!?!?
With 1 normal exhaust and 9 radiator pull exhaust compared to just 6 intake fans (all the fans I could count on your setup), do you have significant level of negative air pressure? Also, does the sheer number of fans make a decent amount of noise?
