The case before I started to work on it again. The dust makes me sad, shows how long it sat haha.
My metal place sent me steel. It shouldn't make much of a differance once its painted, save making the case a bit heavier in the back end.
Marking up the back panel for the motherboard tray.
After a bit of cutting.
A bit more cutting.
I actually ran out of dremel discs, so I had to make a little supply run
Got some of those snazzy new dremel quick change cutting discs
The motherboard tray in place. There will be a sheet of plexi between the tray and the steel, I think I'm going to work on that tomorrow.
My new favorite toy, a right angle adapter for my dremel.
Sometimes a job calls for bigger tools, having a shop with built in air lines is a truly wonderful thing.
A bit more cutting.
