Thanks to ImageShack for Free Image Hosting
Here is a teaser until the metal I orderd comes:
Part from my PC65 unrivited
Mask off section you don't want screwed up
Then start to cut. Using dremel w/ reinforced cutting disc 20 for $5 and walmart :0
Now the other side!
More masking off!
More cutting!
Looks right to me, just needs a little filing and will be perfect!
Back plate of mobo tray from lian li un riveted
Now the other side!
More masking off!
More cutting!
