Project: Green Machine
EnGbudd
Hi guys this is my first post on these forums, i have been reading these forums for the past few weeks and have been amazed at some of the things i have seen. I have been interested in case modding for several years now but have only really done the basics such as paint and cathodes.
So i decided to start a new project. i recently bought a full tower case off ebay for a hefty £30. I plan to paint the inside chassis with dark green enamel paint, The outside parts with satin black enamel paint. I also plan to cut 2 blow holes in the top panel and one intake fan hole on the front bezel. I will then pimp it out with green cathodes and some green LED fans.
I used sketchup to show you what i mean. This is my first time using sketchup so sorry for the bad quality.
my.php
[/URL][/IMG]
my.php
[/URL][/IMG]
my.php
[/URL][/IMG]
Please tell me what you think :D
Hi i got the case, i wanted to see how everything fitted inside so i just put my old rig in it :D heres a few pics.
Post me your comments :D
Man, that case is huge! Wish I had the cash to buy one of those for a file server.
Good luck on the mod!
Yeah i got 25 days till i get paid lol so i cant do much with it at the moment. I could buy some sandpaper and start the sanding, but i would rather do everything at once.
So i will do as much as i can and keep you updated. Thanks guys.
