Project: External Radiator Case
Spotswood
I've been commissioned to build an external radiator case which is destined to sit on the top of an 800D. The case will be made entirely from aluminum and built to house two triple radiators.
Here's a drawing of the case:
The frame of the case is made from 1-inch channel, 1/2 x 3/4-inch and 3/8 x 3/4 flat bar.
The corner blocks were made from 3/8 x 3/4 flat bar:
The alignment of all three corner pieces turned out to be spot-on:
The frame is fastened together with self tapping stainless screws.
I absolutely love your work Spotswood... subbed for sure! Looking forward to seeing this come together. Thanks for all your high quality posts!
@xDezor - Thanks.
@SuperTroye - Thanks. I'm eager to see how this turns out as well. hehe
Tossing in a sub here as well. Enjoy seeing the creative ideas that Spotswood comes up with.
I cut out the bottom, top and sides of the case with my hand held router, guided by a straight edge.
The entire bottom of the case is perforated aluminum so as not to impede the exhaust from the 800D, eventually standing on some nice beefy mnpctech case feet.
Side panels bolted on with stainless steel socket cap flat head bolts.
Up on mnpctech case feet:
Thanks. I use Google's Sketchup.
Huh, I didn't know Google Sketchup had such a nice look to it. I'm a SolidWorks junky. But I might have to give Google Sketchup a try for renderings that don't require CAM.
how will the rads be set up? blowing in opposite directions with the small ends of the box being the intakes?
Fantastic. I've thought of attempting something like this myself and then switching my main case to something much smaller and attaching the WC case via QDs.
I think this will be a push setup, out of the case. The intake will come from underneath.
Yes, this case will have holes drilled for quick connect/dis-connects.
Cut out the openings in the sides for the rad exhaust.
The back of the case has a removable sub-panel to make it easier to reconfigure things in the future:
I drilled two 18mm holes for Koolance's quick-disconnect panel fittings.
Small update...
Taped the top support beams for #6 bolts and attached the top sheet with six stainless steel flat head socket cap screws.
Cut the perforated aluminum which will be affixed to the side panels using Hi-Temp Lab-metal.
Cut a slot in the back "inset/sub-panel" for the power cord.
Cut the front sheet, routed out the hole for the 5.25-inch bays and squared the inside corners with my trusty file.
Completed the cage for the 5.25-inch bay devices.
A full size printout from a Sketchup model was taped to the .10-inch aluminum sheet.
A 3/16-inch router bit and plunge router were used to router out the mounting slots.
Two small pieces of 1/2-inch angle and the "cage" was done.
Wait, you can print to scale from sketchup?
Why the fuck did I never try that before. Shit.
You're my hero - and your metalworking skills are top-notch. Those are some straight ass cuts. GJ
I added the radiator supports, made from .25 x 1-inch and .125 x 2.5-inch aluminum flat bar. I hope they are strong enough. ;)
I'm impressed all over again every time I look at this build. Well done!
