Time to work on some parts inside the case. The pump will be placed near to the motherboard. The area around the pump is covered with an black aluminium sheet from AC Ryan.
The aluminium cover around the pump also comes in handy when I have to hide some cables.
The pump itself will be covered by its own housing. I used some acrylic piping and cut it in half. This is just the base of the pumphousing, now I can add some more housing parts by glueing it onto this pipe.
I can finish the construction of the hddbox now, this because of some great help from a company nearby in Eindhoven
called Nebo http://www.nebobv.nl/
Now it fits into the pipe.
I drilled two big holes in the hdd box.
These holes are there for the acrylic pipe that will go through there. I glued some black acrylic around the pipe. This is needed to attach it to the hdd box with some bolts.
Couldn't glue it because I will need some space to adjust the construction when needed.
A quick look underneath the hdd box.
The two pieces of acrylic that fit into the pipes underneath the hdd box will be mounted on the bottom of the case. To prevent any movement I will use some aluminium profiles underneath the bottom of the case, but this will not be visible. This construction will prevent the box hanging in the rc shocks from flipping to one side.
