Almost there....
I started filing all the pieces as you can see. The outer piece on the right is the best place to look what I mean. I will have to add one small piece of acrylic on the sides and then it needs more filing and sanding before I can use a small torch to make it shiny again. It already took me four days to get this far and I will have to do this work another three times
