Justintoxicated
- Apr 10, 2002
I wanted to make things easy on myself as this will be my first water cooling rig. So I decided on the following parts.
Cooling
CM Stacker (Origional) $155 shipped
DD TDX waterblock $50 (with nozzel kit)
Thermochill PA 120.2 $108
DD D5 $55
DD Low Profile Maze 4 GPU cooler $44
DD Fillport x2 $24
Worm Drive Clamps $10
Audi/ Volkswagon Coolant $30
Swiftech BGA Memory Sinks $20
7/16th inch tubing from McMaster $11 Shipped
Hardware:
DFI Expert NF4 $190
Nvidia 7800GT $300
WD Raptor HD 150 $280
Lite-On DVD Burner $50
Sunbeam Rheobuss $10 (SVC)
Enermax 620 Liberty $185
Fans:
2x Panaflow L1A 120mm x 38mm $30
1 AOC Aluminum 120mm Ball Bearing $10
Misc:
Weather stripping foam $2.50
some Allenhead bolts and nuts for Fan Grill $3
Lowes Brass Ballvalve. - $5
Artic Ceramique - Already had
AS Epoxy - Already Had
Various Thumbscrews $10
Tools:
18V Drill - Harbor Freight Discount -$20
1 inch Holesaw (Craftsman $13 or something) - Killed after one hole
Various files (round flat etc)
Pliers
Needle Nose Pliers
Sand Paper
Duplicolor Metalcast 2 cans $14
Well here it is, arrived nice and healthy.
Got the PSU, and it did not fit! I had to remove the Fan Grill to get it to fit into my case.
Cooling
DD D5 $55
DD Fillport x2 $24
Hardware:
DFI Expert NF4 $190
Nvidia 7800GT $300
Fans:
Misc:
Tools:
Pliers
Needle Nose Pliers
Sand Paper
