Project: DOOM - ZenModz
Zenator
Hello again.
A build based on the new DOOM game.
This Build will be entered in the Cooler Master world series Case mod.
Intro:
With this build I'm not going to try and better or match any other past doom builds,
I'm just going to give my own style of the new Doom game how I see it and the only way I know how, And that is to mod the crap out of it. I hope you enjoy the ride. This build only has a 8 week life span as it must be done before the last day for entering the Cooler master world series. So I have a real lot of work to do to get it done in time.
Before we get started I would like to thank all my new sponsors for believing in me, And for all your support you have given for this new build,. It means a lot to me.
To start off here is some of the coolest gear from Cooler Master.
Pun intended. :D
The Master Pro 5 case that will be used in this build, as well as the CM 850 PSU,
CM Silencio FP 120 PWM fans, And to top it off I will be painting a CM STORM MECH Keyboard to match the Master Pro 5 case.
I will go into more detail for each item as the build moves along.
To start of some photo, of the work I have done so far over the last week.
MR creepy well that what I call him. and for some strange reason no one I know like the look of him. not sure why.
He started off as two blocks of sign foam and glued together with a thin layer of body filler. and a rough drawing of where I think things go.
The entire build will be done all by hand or hand tools. no 3d printing or any cnc used.
Next the dremel come out to play. and some 120 grit sand paper.
So far so good. ?
Next is the Clay. Oh god now what, I'm thinking to my self! where to start ? Let me just say this is the first time I have tried doing some thing like this so it took some thinking before adding the clay.
I used ping pong balls for the eyes as they looked close to the eyes so thats what i used.
I have also started adding the space for the teeth which after doing all the top ones, i found that they where all to wide so later one I re-did them.
And here are some more photos.
Started adding some pins for the teeth. as well as the center bones for the eye brows
And here the inside of the bottom jaw.
Now the holes for the teeth on the bottom jaw.
Here I have cut the bottom jaw out to make it easier to work on.
More pins, And look his first tooth how cute.
That soon changed. :paranoid:
And then there where more.
Remember what I was saying about the top teeth holes fix now.
starting to add more detail now. and have fitted the bottom teeth back.
Here I'm adding the gums hanging off. Should look good when painted.
Case Striped down to be painted.
And back into shape.
That all for now more again real soon.
Thanks for stopping by.
Keeping it going.
Some mesh for the hand that I'm going to start making.
Starting to cover the mesh and added the wire for the fingers.
Added the bends for the fingers.
More on that later on for now back to the skull.
I added a drip what should look like blood dripping once painted.
What I have done next is sprayed the skull in some high-fill 2K primmer when dry I will sand with 600 grit paper. and then I will paint the skull Bone white.
Now dry enough for sanding.
Thanks again for stopping by.
More again soon.
If I only know how much fun this was before. I would have been doing this years ago. Hope you all like it so far.
Thanks for stopping by!
awesome work! Looking forward to following this project! Did you use super sculpey for the hand?
Cheers, dr.stevil yes I did and wish I had used it for the Skull as well. :)
Hi
Got some of the painting done today mostly the skin and nails on the hand.
and will do the rest in the morning.
haha yeah, that stuff is amazing to work with... although haven't used it in quite a long time. Awesome modeling and paint work! Keep it up
Amazing work! Can't wait to see more! (y) That's some talent, I can't even carve a decent pumpkin!
Don't look if your skittish around blood.
That's all for now,
Reactions: Derf
Hello again.
Not giving to much away on the case ATM. But it is well under way.
if anyone wants to know how the can it still be opened I'm making it so all the panels can still be removed.
To start the ball rolling here is the Mobo process.
The Mother Board going into the Doom build is the ASUS Sabertooth X99 2011-3
The link can be found here : https://www.asus.com/au/Motherboards/SABERTOOTH_X99/
I think a very cool looking Mobo to start with for the Doom case. and should work well with the theme with it's armor plate cover.
What I like most about this Mobo is all the extra bits that come with it like the PCI-e covers and a plug for every thing plus a fan that can be add to the Mobo for some better cooling that I'm going to be using.
Plus you get 4 ram bank fillers to hide the empty ram slots. as well as 3 thermal sensors that plug into the Mobo.
So to start off I have removed the Armor to get it ready for it to be painted in silver.
Ok here come all the PC goodness so I wont do much more talking as I know most of you will just look at the pretty photo's
All Silver. :)
Adding a small amount of yellow. more yellow will be added to the inside of the case later.
Here I also repainted the text onto the hole mobo. to make it all stand out.
For the next photo's I have done a small amount of weathering on the Mobo.
Thanks to Cooler Master and AVEXIR I get to use some sweet looking BLITZ Series AVEXIR Ram. You just have to love how good there ram looks.:D
But I'm still going to mod it just a bit. to work in with the look of the Mobo.
Black.
Now silver.
And now even sexier then before.
Here is the Mobo completed :p
That it for now, As always thanks for stopping by.
Reactions: Derf
Hello again.
First off for this week Cooler Master sent me some A cool t-shirt and a drink container for being part the the Cooler Master World Series. Thank you CM I will wear it with pride, :thumbup:
Sadly Ive been told I look bad in photos. What do you think ? I was Home Alone at the time. and was a bit scared when the flash went off :D
So the build is still moving along, I started off making a airlock door. and some rails for the inside and some other parts, then moved on to the case again.
The Rails relay suck to make. just my 2 sense worth. And yes I need to make more! :upset:
All of this build is hand made, cut out mostly with a sharp blade and other hand tools.
Still adding to the look of the case as I go. Below is where I'm up to so far.
Some parts are being shaped with sign foam to make it a bit quicker.
That's about it for now. I'm waiting for the water cooling gear from Bitspower to arrive then I can start getting the inside up and going as well. :D
But for now I'm trying to get the outside all done, Not all that much more to go on the outside. just lots of small bits.
Again thanks for stopping by.
Hello again.
Here are some more photos again hope you like them. :)
elevator door.
elevator power box. and will light up.
More elevator parts. this is the top cover.
And for the rest. Hope you like them :)
Still looking to add a vent here.
Still lots more to do. and more to add to it as well, I hope you all like how it's coming together let me know what you think all feed back is welcome :)
Thanks again for stopping by. :)
Pretty impressive. Your ability to make it look weathered is incredible. Are you using an airbrush to create that effect? Also, are you the same person that did the Mars City mod when Doom 3 came out?
Thanks Krenum. appreciate the feed back. yes airbrush and paint brush. No I did not do the Mars City one. this is my first doom case mod. :)
Doom PC still going strong,
Received some Very sweet looking cables from modGuru and made some small changes to them to match the inside of the build.
Added a grill the the top of the case.
Now painted :)
I have also finished off the back side panel to help make it blend into the case.
After adding some more weathering to the side panel I think it now just works with the rest of the case.
Thanks Again for stopping by.
Very awesome, Glad to see the Doom 3 Pentagram logo on it.
I don't know what you do for a living, but you have some mad modeling skillz. I can't wait to see the final product.
Hi everyone.
One update till Sunday.
Is Mr. Screams Alot going to have pupils or is he meant to not have them? Either way has artistic potential.
I'm just curious on how this will look finished. Fantastic work so far.
Also, out of the crazy amount of detail here, the one thing that impresses me most are simple details like how the blood on his forehead still looks wet and the lighter, more watery trail underneath showing the path the blood droplet took. Simple things like that can be overlooked easily.
Thank you Krenum :)
Thank you Temo Vryce, I work mostly as a spray painter. But very much still a starving artist. :D
Thanks Capt, yes the eyes stay looking like that but they will have LEDs to light them up, And thank you for taking the time to have a good look at what I have done. :happy:
Cheers, Ken.
Hi, It update time again and I'm sure some of you are keen to know what the inside of the Doom case is starting to look like, So say no more!
ASUS 970 GTX Being changed over to water. Thanks to Bitspower :)
Ok here is the photo's you been waiting for.
Tubing and floor plates for the case and GPU.I will still be adding more to the plates.
2x140 Coolermaster fans get a new look for the top 280 rad.
This should give you some idea as to the look of the inside of the Doom case. And before someone asks why there is one the tubes running across the center, When the side panel in on the pipe can be seen sitting just above the two top windows from the outside of the case. will add some photos of that tomorrow.
Hope you all like it. Thanks again for stopping by.
Hi Main Doom door, It's small for a door and need a bit more detailing but It's a Door. :) Plus I finished off part of the lift. and the side windows show some of the cooling inside.
Thanks again for stopping by and having a look.
Hi every one,
The Doom build is just about done, Just some small details to go.
Sadly there will be no cooling fluid added to the build for some time to come as I don't have a CPU for the build yet.
