project: Category 5 Cyclone - C5C
masbuskado
I start this project in 2008 a couple of months after I finish my AirSupreme I and this one was the sequel AirSupreme II but as you may know my "AirSupreme I" evolve so I let this project out of the picture, but know I rename the project and I'll take over once again... so the concept is the same as AirSupreme I or EvO but with 120mm fans... new light color scheme, some custom modification and more air flowing...
Also this will be my first Inter-Forum thread meaning that this thread will be post in any Forum am subscribe. So it will be update simultaneously in all of the forums.
As always there is no plan cuz whatever came to my mind I'll try to do it...
So feel free to give your opinion, comment or disagreement cuz we know can't like to everybody...
So let's the mod begin...
Sponsored by:
newmodcity.com (2x 140mm Fans, 2x 140mm Custom Fan Grills and 3x 120mm Custom Fan Grills)
OKGear.com (4x 120mm Hex Mesh)
You did a great work with your last case :D Good luck with this now! :)
The Storm Cage by masbuskado
The Main Idea is... to put a real storm inside the case... yes a real storm...
So I need the 3 basic components for that...
1. Wind: Strong winds... For this I'll need 2x powerful 140mm Case Fan. Don't worry about loudness... Looking something around 120 CFM (already see all newegg fans - budget $30)
2. Water: Heavy Rain... For this I'll need some kind of tiny sprinkler to create some shower effect (1/4" or 1/2" will be good).
3. Lightning: Massive Thunder... I was looking for some flashing blinking disco light tiny enough to fit into the build (already founded see pics).
All the components will be added into The Storm Cage I'll make out of acrylic...
So basically right now I'll need some help finding the fans and the sprinkler just point me out where I can found them and thank you!!!
I'll explain how this thing gonna work later...
Hmm , I don't know how to found the things you want even in Sweden, but what about the fans?
thanks man!!!
somebody give me an idea I'll try it and I'll keep everybody update about that...
thanks for you help luv the idea with the plastic bottle but is too big to fit into the case...
here is a pic of the fan I'll be using
http://www.newegg.com/Product/ShowI...80-06.jpg,35-185-080-07.jpg,35-185-080-08.jpg
How it Work - The Storm Cage
I think this should create the Storm Effect base on my previous test in my lab... :D
:( was kind of busy doing some cyber-setting but I have all the material sitting around so expect an update next weekend or maybe during the week!!!
Take care guys!!!
cool project
how big's the reservoir going to be?
with that much airflow for the "wind", i'd assume that there'd be a considerable amount of evaporation and refilling the reservoir would be needed...
C5C - Category 5 Cyclone
2x 140mm fans, 2x 140mm Custom Fan Grills and 3x 120mm Fan Grills thanks to newmodcity.com
4x 120mm Hex Mesh thanks to OKGear.com
Next week I'll start building the Storm Cage so stay tune!!!
[Completed] Building the Storm Cage Part 4 - May 18, 2009
Finallly I accomplish the Storm Cage Idea!
Now I have to wait until it dry to do some test!!!
Things to do: Drill a hole in the bottom to connect the custom reservoir and another one at the top to connect the pump and build my unique loop :D and let the storm begin!!!
I'll try to upload the video tonight!!! so stay tune!
Category 3 - C5C
Making the Case Feet! - May 19, 2009
That's all for now!!! I'll continue this project next week!!!
Now I'll be back to my other Project: Orion Pax
Looks great, awesome work.
So, what if your video cards have side power connectors? did you leave room for that with the storm tank?
Category 4 - C5C
September 23, 2009
Finally I manage to make some time for my previous projects!!!
[PAINTING]
