your hard drive rack looks cool but the mounting seems funky. it looks like you're planning to mount all the drives by screwing them in from the bottom. that'd be a good system and all but pretty impractical if you need to change a drive out. can you explain your hard drive mounting system a little better so we know you're not crazy?
otherwise i like the build, i'm a fan of big server cases and the metal frame looks cool. the outside is a little shiny for my taste but i supposed you could change them to brushed aluminum panels if you wanted to later on down the line, since you have the basic framework set up well. panels are just cosmetic.
