program to test sli
DieHard007
is there a program to run and see if your sli setup is functioning right or let you know you are running in sli
The Nvidia control panel will clearly state if SLI is enabled or not. To test just set it to AFR 2 forced rendering mode and run a game, then disable it and run the same game. Framerates should drop, unless it's WoW or one of a few other titles that've proven to not benefit from SLI at all.
does Nvidia still ahve the green bar indicator?
there used to be an option that would let you turn on SLI overlay that would show you each GPU load and a green line where the scene was split (for Scissor mode)..
I just use 3dmark06... I mean you will see 88GTX go from about 50-60fps to 90fps... yep working! :)
