Program to limit WiFi speed at certain times
Discussion in 'Networking & Security' started by RashMullah, Mar 10, 2018.
  1. RashMullah
    RashMullah n00bie
    38
    Oct 28, 2010
    Hi guys,
    I'm looking for some advice on how to limit my wifi broadband speeds at certain times of the day. Is there a program which I can install which would set wifi bandwidth to throttle during a set time period like 2pm to 7pm in the afternoon?
    Thanks in advance for the help!
  2. SixFootDuo
    SixFootDuo [H]ardness Supreme
    4,832
    Oct 5, 2004
    Go into your router. Most modern wifi routers have speed limit scheduling if I am not mistaken. There are also external software solutions as well I think.
    I'm not in a situation where I would need that so I've not investigated it much but I've seen that capability many times over just browsing through.
    Once you find it I'm sure it's easy enough to setup.
  3. Brian_B
    Brian_B [H]ard|Gawd
    1,571
    Mar 23, 2012
    I’ve always found if you use Comcast they will throttle for you during those times, free of charge.
    dvsman, c3k, Cmustang87 and 1 other person like this.
  4. DigitalPanhandler
    DigitalPanhandler Limp Gawd
    144
    Jun 30, 2016
    Lol
    But on a serious note yes check your modem/ router If you have Comcast mine has a option to limit bandwidth and times of use. I let my neighbor use my connection for a small fee (though I do have business class.) I'm relatively certain the modem/router are the same as the residential versions from what I've seen
  5. Cmustang87
    Cmustang87 [H]ardness Supreme
    4,282
    Oct 4, 2007
    What router do you use for your home network?
  6. heman22union
    heman22union n00bie
    42
    Nov 6, 2013
    I'm interested to see what you come up with.
  7. cheap50
    cheap50 n00bie
    44
    Feb 27, 2018
    Fortigate 60D's are smaller, easier to setup and use and do this well.
  8. Vengance_01
    Vengance_01 [H]ardness Supreme
    5,535
    Dec 23, 2001
    Unifi gear can do this on there APs
