krnbrucelee
- Jan 2, 2010
how do i remove the product key from one computer and move it to another?
is that even possible? thank you!
ahemm.... Very Very possible.
Take a razor blade and slowley peel the edge up.. Then work it from side to side untill it pops off. Then reapply with new glue onto new case. ...
Hair dryer on the backside of the sticker, scrapwe with razor after it loosens.
http://images.dr3vil.com//files3/51/base_media.jpg
Just take your time - Enough said.
