Processor/Motherboard difficulties
Taskism
Hey guys, this sites been the most useful for pc help, so im back.
I had a 3.75ghz Pentium 4 processor I got my hands on, but it turned out to be a Xeon processor, so it wouldnt work when I bought a motherboard for it. The motherboard I bought was the Asus P5GD2 Premium. The Xeons were Nacona's, and when I powered on with the processor in, it gave me the error through the speakers saying System Failed CPU Test. So I talked to somebody at Intel, and they realized it was a Xeon processor, so we went back, and got a couple Prescott processors, and a few of them say the same "System Failed CPU Test" messege, and one of them just causes the computer to shut off when you turn it on. It never at any point gets to any output to the monitor.
I called Asus, they had me do some troubleshooting, and they said its either the processor, or the motherboard, and to test the processor on another system, and if that works, call them to get an exchange ont he motherbaord.
The processors work, so it looks like it might be the motherboard? My dog shreded the recipt for the motherbaord though so im kinda fucked. Anyone have any input on the whole situation?
Thanks in advance.
Task.
A xeon CPU would not fit in the socket of that motherboard.
You should doublecheck the part numbers and reask the question with a complete rundown of parts you're currently using.
Edit:
I read your other post about getting the wrong CPU for this system.
1. Intel does not make any 3.75ghz CPU, xeon, P4, celeron or anything. It may overclock to 3.75ghz, but it's not offically from intel at 3.75ghz. They do make a 3.73ghz P4 extreme edition that would work in that motherboard, but it requires DDR2-533 ram in order for it to work correctly. That CPU costs about $1000. Do any of these parts sound like something you have? Do you still have the box the CPU came in?
2. There is no physical way for a socket 603/604 xeon to fit into a socket 478/775 motherboard.
Edit #2:
I read your other other post and if you really have an EE engineering example CPU, consider yourself lucky. When someone gave you that CPU did they say the RAM worked with that CPU? Not all DDR2 is equal, as they have both DDR2-400 and DDR2-533.
Ok dude, it is 3.75ghz, its not retail, thats why you are on the lines of thinking it dont exist. It was a Xeon, and its a socket T (775) Xeon, and the DDR2 Ram Im using is used with it all the time where I got it, the ram and cpu are totally compatible. I was told there are three switches in the processors, and one of them tells if its Retail or non-retail and they think it might not work with the motherboard because its reading that its not retail. Thats from an Engineer at Intel.
so Im think its either that, or I got a bad motherboard. Dont know witch, thats what Im here to clear up.
but the processors I used were a socket 775 Xeon, and some socket 775 Prescotts. The processor and ram are all good.
Take a look at Intel's server CPU roadmap and you'll notice NO 3750mhz xeon's on there for this year.
This is the part where you say 'ok its an engineering sample :rolleyes: '.
Then I say ok, but there are no LGA775 socket xeon's coming out EVER according to Intel. All Xeon's are socket 604. According to Intel's roadmaps, LGA775 is for P4's only, not xeon's. If it is what you say it is, it is a rare beast indeed. You could sell this CPU on ebay if you could guarantee it works and make enough money for a whole new SLI rig probably.
Whoever gave you this CPU may have a compatible Intel engineering example motherboard too.
Do you have the s-spec of this CPU? It should be 5 characters, the first 2 are SL. Pictures of this never before seen marvel would be nice too.
I think its funny/amazing that you have a CPU that hasn't been reviewed anywhere by the big hardware sites.
But back to your question, if those Prescott's didnt work either and they were installed correctly, you most likely got a bad motherboard.
I had a motherboard for it, but it was BTX. I was thinking of going back to that motherbaord and just looking around for a BTX case.
Im not here to argue about the Xeon and if it exists or not, and Im not gonna post the numbers on it, cuz I dont wanna get anyone in trouble ;) They build a lot of systems at Intel, not all go to retail.
