Problems.
Fynath
Alright. I just got my RMA'd board back from MSI today (I'm pretty sure they sent me the one I sent them back, so maybe it wasn't dead...). Since I thought it was the board I'd sent them, I figured I'd just plug the psu into the mobo, and the case speaker and the power switch to see if it would beep. I turned it on, and didn't get anything.
I then put my cpu/heatsink/fan and a stick of ram into it, and tried powering it on again. The fan spun for about a second, then stopped spinning, so I figured it'd powered off. Tried to turn it on again, but it wouldn't start up again, so I held in the power button long enough that it would turn off normally, then tried it again. Powered up/fan off after a second. So I took the heatsink/fan off and then put them back on, and powered it up again, and it was fine (aside from my monitor receiving nothing; had it plugged into onboard vid). I then noticed I'd forgotten to plug the 12v molex into the mobo, so I turned it off and did that, then when I turned it on again the fan stopped after a second.
All throughout this, I got no beeps from the board, and I had it on the bag it came in to make sure it wasn't shorting out. Any idea what the problem is? Maybe my processor?
This is the mobo: http://www.newegg.com/product/product.asp?item=N82E16813130473
CPU is an Athlon XP 2200+
Also, the board was new, my old one died on me (or so compusa told me, at least). It just decided to stop posting. This one seems to be having the same problem. (I really don't have much of an idea of what I'm talking about, other than what I think I've learned from reading threads on this forum..)
Make sure CMOS jumper is in the right place. Move the RAM around to try different slots.
What PSU do you have? I had a simliar problem like that, and it ended up the PSU was messed up (the 12v wire was the 5v wire, and it kept frying my optics). It wasn't until awhile until i figured it out then unplugged it and it didn't short out the PSU anymore. Also look for shorts on all the Power plugs and molexs....it really sounds like a PSU prob.
Alright, I will check, it's a brand new 350W Antec PSU though. I bought it when someone else suggested that the problem might be the PSU, so I doubt it's though
