Lazy_Moron said:Did you hit apply? May sound stupid, but in my experience the most obvious answers are the hardest ones to findIf not, what brand is it? Also, you need that overclocking program to stay running in the backround to keep the overclocking settings.If you have the program shutdowned completely, those overclocking settings will not take place.
ncantador said:On ATItool check to make sure you don't have the core and memory safety range set too low. Also make sure you have the latest versions.
MakubexGB said:Try using Rivatuner to overclock your card. Also, just in case it matters, go into the Catalyst Control Center, go to Overdrive and unlock it, if it's locked (if it's locked, the lock icon on the top right should be closed).
