Problems with SN25P
kennedy
Specs: SN25P stock with AMD 64 3700+
1 gig Patriot PC3200
Diamondmax 10 SATA 300gig
BFG Nvidea Geforce 6800
Sony DVD Rom Drive
I have had numerous problems. First i would have my system to to a blue screen at times saying its doing a physical memory dump then restart. Other times it will just freeze whether its on my desktop or while i am playing a game. Some times it just restarts randomly. Most times it goes to a black screen and says windows has encountered an error would u like to boot in safe mode, safe mode with networking, last known good configuration or start windows normally. Other times it says there has been a "Disk Boot Error". I have tried numerous things which i thought might ave been cause of overheating. I leae the cover off of the case and it still does these various things. Any help would be appreciated. Thanks
Greg
Sounds like it could be a memory issue. Run Memtest86 . Is this overclocked at all?
SN25P's also have had bad SATA cables that can do some funny things. Also, make sure you're running the latest BIOS.
More good SN25P info here .
No it isn't overclocked at all and i had run memtest and it said everything was fine. I dont have a floppy drive and im kinda of weary of updating my bios
ok i updated the bios and all and its still hanging on boot and randomly freezing. to hange the SATA cables can i get them local or i have to order from newegg
Just get em from where ever you can get em :) get named brand ones though. I used Akasa SATAII SecureLatch cables in my old SN25P and worked really well
it is a sata cable problem you have to swap them out if you're having the problems you mentioned.
same thing happened to me. i swapped the cables, and everything runs great!
If it is the SATA problem and you're having problems just be thankful you aren't running a RAID 0 array like I was when my cables went sideways. Lost everything that wasn't backed up, not critial but still a huge PITA.
so any old SATA cables will work? do i need a certain kind or whats the diff
There's no technical difference between SATA cables. Other than length and colour.
Just get one from a named brand such as Akasa so you have higher quality cables.
There is a great SSF site called sfftech.com, there fourms have some good post on this subject.
