i just bought an Abit NF7-s v2.0 to replace my old motherboard, and i'm having problems.
my setup:
Abit NF7-S v2.0
Athlon XP 2500+ Barton @ stock
GeForce FX 5900U @ stock
1GB Mushkin PC3200 in dual-channel @ 333Mhz (1:1 w/CPU)
30GB Maxtor IDE hard drive on SATA channel (using serillel adapter)
Tekram DC-200 ATA100 RAID controller card w/2x Western Digital 120GB HD's in RAID0
WinXP Pro SP1 (will install SP2 after i figure out these problems)
what happens:
i used a Win98 boot disk to format the drive on the SATA adapter, then booted again from the WinXP cd to install Windows, keeping the current file system intact. i hit F6 to load the latest version of the SATA drivers, as well as the latest drivers for the Tekram RAID card, and let it do its thing. after copying the files, it wants to reboot, so during the reboot, i change the BIOS back to boot from the SATA adapter, and the setup continues as it normally does.
after finishing the install, it reboots again of course, then comes up into Windows. here's where the problems start. on my RAID array, i have all my setup files stored, which includes all my drivers, Service Pack 2 setup file, etc. i open up that drive, try to run the SP2 setup, and BOOM......system locks up hard, mouse is frozen and keyboard is non-responsive, not even ctrl+alt+del works. during this time, the HD LED on the front of the computer is solid red (no flickering whatsoever), so i leave it for a few mins to see if it will recover....nope.
so i reboot, download the latest nForce drivers and install them, thinking the generic chipset drivers just can't handle it.....wrong.....start the SP2 setup again.....PC frozen.
reboot again, try just copying the SP2 setup file over to the desktop to run it from there......PC frozen.
i jump onto my second system, come here to do a search, and see that it's generally a bad idea to install the nForce IDE drivers, which i did while installing the nForce driver package.
ok, so since the freezing/rebooting has caused some files to become corrupt, i totally reformat again, reinstall windows, then install the nForce drivers minus the IDE package. try to copy the SP2 file back to the desktop...PC frozen. at this point, i'm totally pissed, so i leave it frozen for about an hour while i go eat & take a shower, come back, and it's still frozen. shut down the computer, unplug my CDRW drive from the normal IDE port and connect the HD to it instead of the SATA adapter, reboot, and everything copies over from the RAID array with no problem whatsoever.
so at this point, i update my BIOS to the newest version on the Abit website, and made sure the Tekram RAID card's BIOS is up to date as well. put the HD back on the SATA, try to copy any file larger than 20MB or so....PC frozen.
try the other SATA port....PC frozen.
so then i think that since the BIOS has been updated since the last install, maybe a final reformat/reinstall will do the trick. now the damn thing won't even boot from the SATA adapter at all. i can format the drive from the Win98 boot disk with no problem, i start up the WinXP installation, selecting F6 to load the SATA & RAID card drivers, it copies all the files onto the hard drive, then wants to reboot. set the boot order back to SATA, get "invalid boot disk, replace and press a key to continue" (or something like that, i'm not at home right now, or i'd copy it verbatim....and yes, i made sure there was no floppy in the drive). i can set it to boot from SCSI, and the setup continues, but now i find that my RAID array is the c:\ drive, and the OS drive is d:\ & e:\ (two partitions, obviously).
i'm basically at a loss here as to why this is not working....the only thing i can think is that the serillel adapter is FUBAR, unless someone else has any other suggestions? i've got a second serillel adapter on the way in the mail from my brother who has this same mobo, he has a native SATA drive so he doesn't need it....i will be trying that when it gets here.
and don't tell me to just go buy a native SATA drive, cause i don't have the $$$ for that right now.......
my setup:
Abit NF7-S v2.0
what happens:
