Peteman100
- Oct 7, 2007
I just built a new computer for myself (specs below) and I'm having some strange issues. At first glance, all my hardware seemed to be functioning well after I put it all together. However, I started getting strange instability issues once I loaded Windows. A lot of my drivers didn't want to install properly or would give errors on reboots. Also, Vista would pop errors at startup as well, including one stating that Readyboost had failed to start properly (I didn't even have a USB drive in the computer). And the weirdest part was that Prime95 fails almost immediately on the blend test even though I am at completely stock settings in the BIOS! My first guess would be that the memory is bad but I have them running at the proper voltage and each DIMM individually passed 8 hours of Memtest without a hiccup. And while my CPU temps are funky, with the hottest core 10 degrees higher than the coolest at 60 degrees loaded, those temperatures shouldn't be high enough to be causing instability (And reseating my cooler doesn't seem to help my temps). Any other ideas on what the issue might be or how I can identify the problem??
Vista64
Intel Q9550
OCZ Vendetta 2 Cooler
Asus P5Q Deluxe
OCZ 2x2GB Reaper 800Mhz CAS4
MSI 4850 512
WD 6400AAKS (+ 1 other backup HD)
Samsung SH-S203B DVD Burner
Vista64
Intel Q9550
Asus P5Q Deluxe
MSI 4850 512
