Problems with my MX1000
KillerMonkey
I just had a fresh install of Windows XP and for some reason my MX1000 isn't recognized anymore (it worked like a charm before).
I've tried installing the latest setpoint drivers, but it didn't help.
Does anyone know how to fix this? (Btw, right now I'm using a crappy laptop mouse)
Whoops, no..
I'm such a dumbass. I'll try that!
Edit: It's working now. Thanks.
Edit2: After a reboot, it's not working anymore :\ guess the problem wasn't the service pack after all.
When you say the computer doesnt recognize the mouse are you saying it doesnt work at all or your setpoint doesnt work?
Have you tried another usb port?
Try moving your charger further away from the monitor, that caused some problems in my brothers computer
three generations of logitech. . no problems here :D
Try this:
Remove the MX1000 from the USB port and use a generic PS/2 mouse/keyboard. Go to Device Manager (right-click My Computer and choose Manage. Device Manager is on the left). Expand the Universal Serial Bus Controller section. Right-click each of the controllers listed there and uninstall them until there are no more USB controllers left and the section entirely disappears. Next, right-click one of the other categories (doesn't matter which one) and choose Scan for Hardware Changes. It should redetect the controllers. Next reboot. Once it is back up and running, plug in the MX1000 and see if that makes a difference. I've seen that work many times and if it's the service pack related issue mentioned earlier, that should fix it 99.9% of the time. Let us know...
That did the trick! Rebooted a few times to make sure and it works like a charm.
Thanks for the help. :)
