Problems with MSI K8N Neo2 plat
So I've had this motherboard for a while now, and ever since I got it about a year ago I've had constant problems. The system runs, if you can call it that, but not stable at all.
Memtest fails asap with no overclocking. I can't even overclock one bit without the system failing to boot. I know it's not my mushkin 2-2-2 memory as I can run it in my friends semi identical computer and it overclocks to 2.5ghz no problem.
The system seems to hiccup a lot, and this is especially noticeable when listening to music or watching movies because the audio will just stutter for a few seconds. Sometimes it even crashes the system. During games it happens much more. I play EQ2 and it crashes on me all the freakin time.
The only other piece of hardware I didn't swap out was my cpu, and hopefully it isn't that because I have a new motherboard on the way from newegg. Can't afford to replace my agp 6800 GT so I'm stuck with nforce 3 for a while. Ordered a EPoX EP-9NDA3J. Heard good things about it, but then again, I heard lots of good things about the other one too. Maybe I'll try to RMA it if still applicable once I get the other mobo installed.
I guess I'm just second guessing my deductions on the motherboard being faulty. I know it's not my PSU, I upgraded that thinking it might've been. It's an enermax I want to say 420 watt PS.
I have heard a lot of bad things about the MSI Neo 2 Plat running with faster than DDR 400 RAM, and or RAM that has really low timings. If your RAM ran fine in your friends PC, did you try his RAM in yours, or purhaps any other cheap RAM anything from PC 2100 to PC 3200???
pokehergently said:
I kept the voltage at stock. I tried raising it a few times with no positive effects so I set it back to stock. That is what you are referring to right?
http://anandtech.com/memory/showdoc.aspx?i=2015
That's my memory.
That is high voltage memory. That's probably why you couldn't run it. You need a DDR Booster to get the full effect of it. In fact, it might not even run at stock speed at 2-2-2 without 2.8V or more.
I did try my his ram in mine also, and it stilled performed miserably. He has OCZ something or other I don't remember which one. It was a higher end model I think. I'll try upping the voltage on the memory, which I'm sure I've done before with no effects but I'll try it again.
I've spent hours before going through every possible ram timing, voltage, and a few other settings that were recommended to be adjusted. I'm pretty sure it's just defective. I guess when the epoch board gets here I'll see how the memory runs. I'm not going for an insane overclock, just a fairly substantial oc and good stability.
Well, your board might not give it enough juice even at the highest setting (2.8V maybe with MSI :( ). That was what I was getting at. Need a DDR Booster from OCZ. They aren't too expensive...maybe $30.
I would have to agree. IF you and your freinds ram are higher voltage based mem they will have big issues running at any speed with lower volts. When we say higher volts we mean 3.0 to 3.5 vdimm. The Neo2 setting do not offer anything over about 2.85/2.90. Also what Bios are you running. There are still to manny givens here to yet condem this board. I need to se system parts list and specs..(exact info not im not sure or i thin this) I have seen defective PSU cause these issues as well. I myself am not a real big fan of the PSU you selected. A 420w Enermax PSU is in reality probably only putting out about 300 watts of real power. (also ver dependent on the PSU internal temp) Really this should habe a PCP&C or a Antec, Or OCZ or some other really good quality manufacture PSU thats around the 500 to 550 + range. They also need to have a 12V rail with a amperage rating of 30+ amps. (what is this one?) Have you also tried to set this computer up outside the case. Maybe a short somewhere..? I would also try running the mem @ less aggressive timings. set to auto. Make sure all stuff is set at default speeds and voltages. (try a lower based power memory. Like something using TCCD chips. This also sounds potentially like possible Vid card issues as well. Posibly due to power issues. Also could be mem controller on cpu..Not sure till we get more info. maybe even pics of the build would be great.
For the poster that mentioned that this board doesnt like higher then DDR400.. Wrong.. This board is and was the Ocers choice for socket 939 when NF3 came out. Infact im using it right now to post with using my Opteron 146 @ 3.1ghz (watercooled) with my Gskill mem(PC4400/ddr550 Tccd) running at fsb 310 1:1 1T 3-4-4-8 2.65vdim and it does so playing hours of games and super pi and anything that will test stabillity. So saying this board will not do mem over ddr400 is incorect. Cause i have mine doing DDR620.
So to the OP please give us more info. Im willing to bet you have another issue.
You really think that the board is going to run this badly just because of .1-.5 volts? I'm talking no overclocking, hell even underclocking with loosened ram timings.
Also what Bios are you running. 1.b newest version
The PSU puts out 30 amps on the 12v rail. I'm only running one HD, and one drive so there's not a whole lot of power being drawn besides the video card, which is a 6800 gt.
(what is this one?) Have you also tried to set this computer up outside the case. Maybe a short somewhere..? I haven't tried it in another case, but I've used it before with no problems.
I would also try running the mem @ less aggressive timings. set to auto. Make sure all stuff is set at default speeds and voltages. I've tried many many different timings, spent hours rebooting and rebooting attempting to get more stability with looser timings to no avail.
(try a lower based power memory. Like something using TCCD chips. This also sounds potentially like possible Vid card issues as well. Posibly due to power issues. Also could be mem controller on cpu..Not sure till we get more info. maybe even pics of the build would be great. Don't have a camera to take any pics unfortunately. I've built probably 20+ computers before though, including upgrading my own many times and have never had problems. I know what I'm doing for the most part.
Now, don't you think that perhaps it is just a faulty motherboard? I've never had decent stability with it, and the rest of my components run just fine. I don't believe that this particular motherboard has these super requirements just to run stable, even at stock settings. Now, if you have some ram timings to suggest that I ran that might be of use. I'm not new to this sort of thing and know that this system should be running much better than it is.
Its possible the board could run badly due to only .5 volts. Seen it happen before. Overclocked or not.
6800 GT and Ultra are a lil bit of a power hog. especially on the 12v line. IF your PSU is faulty and not supplying enough it can have the same effect. Just a suggestion.
As far as seting it up OUTside a case on a piece of cardboard... Should be something you or anyone with these kind of issues should try. Be supprised of how many people do find their problems out this way and fix them. its just a basic starting point of good diagnostic procedure.
Once again your mem may need a much higher Vdimm to run at most anygiven setting. Try a memory that has a lower volatge requirement and lesser timings. Like 3-3-3-10 @ 1t and 2t also try a divider.
Problem sometime comes from a defective/bad mem controller on board CPU. has the same effects that you have going on. Try substituting a different CPU in your board see if that changes anything.
Never once did i say you did not know what you were doing. But I have more then 25+ years experince as a PC tech and own my own shop. I build close to 700 units a year and diagnose and fix easily more then that a year. I can tell you from my experince that even some of the simplist things can stump even the most experinced. Now as that you have said to have done as much as you have i would have expected you to post a complete list of componets and settings and know what the stuff is.. (including what you tried in it of your buddies) as well as know what steps you have taken and done and forming a proper diagnostic procedure.
Not saying that the board may or may not be defective Just saying I have seen many other things cause issues that would seem like the board and can be fixed if diagnosed and found. For you to say that the rest of your componets have run JUST fine is a mistatment beings that you have claimed that you have never had decent or good stabillity. And belive it or not yes they do have pretty high specific requiremnets. BTW what type of HDD are you using is it SATA or IDE... If SATA i recomend running on Channels 3 & 4 as they have Locked them down if you should raise FSB the Channels 1 & 2 become unstable and crash If you are having a memtest error and its failing that. I would highly suspect that either the mem has an issue (possibly not enough volt, incorrect setting in Bios, bad mem, OR other thing would be bad CPU beings that the mem controller is onboard CPU and not on Mobo.
Now i am trying to help you and not flame but you seem to take offense to what i posted before. Im just trying to put the obvious in front of you first. Its hard to suggest or help if we have NOT the knowledge of what has been done and what componets are being used. Pics are very helpful sometimes as that we might see something that has been missed. So try not to take offense. With that all said I hope it may help you with your problem. If not you can try to RMA this board via MSI. Most come with 3 year warranty. I found it to be very much Superior to anything Epox makes as i have used it as well. You will find with some homework on this board that it is and was truely the best AGP board for 939 amd around!! . In fact I still use mine and run it Gaming and Overclocked up to as high as 3.5 Ghz and mem @ DDR620.
Oh no offense taken don't worry. I welcome all criticism. I may have sounded a bit short mainly because of how much grief this has caused me and how much time I've spent on it. It's actually been a while since I've ran most of those troubleshooting procedures and I was probably at least a little intoxicated when posting so that's probably why I left out a lot of details.
I don't have any other memory to test here neither do I have the funds to aquire any so I'll have to make do with what I've got. I don't really want to go spend more money right now but is this ddr booster thing to raise the vdimm really something I need? I swapped my PSU with his before he put his system together and mine ran fine for his setup and mine ran no better so I'm assuming that's not the case.
The hard drive is a 160 gig seagate sata drive. Thinking of picking up a raptor somewhere down the line for the OS and favorite apps.
It could very well be the cpu also. If replacing the motherboard doesn't have any effect on the system, perhaps I'll return the board I ordered and pick up an x2 4400+ or something in a couple months. Wouldn't mind the upgrade anyways!
I know this is a great board supposedly. That's why I bought it in the first place. It seems like most of the AGP boards were taken off the market, in particular the better models! Sucks for those of us who don't have the money to upgrade a recently upgraded video card just to find a decent motherboard.
So last night I reinstalled windows xp. Had to restart the installation 5 times due to it stalling at certain intervals. The odd thing about that was the first time it almost finished. Then the other 3 times it stalled at exactly 34 minutes left. Last time it went finished. When I say stall, I mean the system just sat there, the mouse would work but otherwise the system was completely unresponsive. This is using SATA channel 4.
Ran memtest last night for 10 hours straight with 0 errors. Other than the ram just wanting more voltage to run properly (which it did not need in the other computer, I believe I had it at 2.6-2.7v) it appears to be ok.
When the other motherboard gets here I will pull this one out and start it on coardboard and try running other steps. The problem is I won't have another CPU to play with, nor another power supply. I don't really have any more money to work with, didn't really think I would need to buy more parts when everything in the system is relatively new.
Argh, the system runs awesome when it's not crashing. Slapped on the quake 4 demo and although I get great frame rates @ 1650x1080 4xaa and everything set to high I can't play it for more than 15 seconds without the game crashing.
Thanks for all the suggestions.. I guess I'll just have to hope luck is on my side when the new motherboard arrives.
