problems with lan - im clueless where the problem is
game14
Im connected to the internet with a motorola cablemodem thats connected with my pc thru the lan port . Now i did some modding work on my rig taking everything apart and after connecting everything again ... surprise "no internet" , no lan connection found . Checked everything , everything is connected fine . Hooked up my laptop and another old pc to the cablemodem and no problems at all connecting to the internet , neither with my friends pc . So the modem is working fine .
I replaced the current HDD with another and did a new windows and driver install on it , trying to figure out if the driver or OS is the problem . Nothing - same problem . In hardware manager the lanport shows up as active and working like it should . No driverproblem . But it doesnt find the modem on the lanport - errormessage is always "no connection found".
I tried to hook up the modem with an usb port - same thing , no connection found .
Im pretty clueless now where the problem might be . Modem works fine with every pc i connect it to , but not mine . :confused:
Specs of my rig in my signature . OS is Windows XP pro SP 2.
Is something wrong with my mobo ???
Thx in advance for your help .
Typically no drivers are needed for a cablemodem if hooked up via ethernet. My best guess would be that either the drivers are not installed properly for your network card that is built into the motherboard or the network card is not setup for DHCP and is not picking up an IP address.
You could open a command prompt and type in ipconfig /all
In the output you should be able to find your network card and then below that the IP address, etc. Post with that info and we can tell if it's getting an IP or not.
yeah i know , i meant the ethernet driver from the mobo . No driverproblem reported .
The second thing i did was installing the drivers to hook up the modem via usb port , but i got the same error message "no connection found"
nop it doesnt find the IP , with the repair option in lan connection to update IP it shows the same message "no connection found to update IP "
message " non valid command"
its really drivin me nuts , i unplugged the cables from my rig and plugged it in several times and there never was any problem at all , modem on modem off didnt matter . Now i just unplugged it all to change the sleeving on my cables ... everything is fine ,no changes to settings at all - exept i cant connect to the modem , never had that before .
No probs with my laptop , can plug the network cable in and out as often as i want and it keeps working .
:confused:
you didnt type it correctly try again "ipconfig /all" there is a space between the "g" and the "/".
This must be done in a dos command prompt window. if you get that to work regardless of the output (post it here if it gives something, but nonvaild command is not possible if you type it correctly. )
Then do this, if your ethernet port is working properly you will see something like below.
ping loopback
C:\Documents and Settings\Administrator>ping loopback
Pinging adrie [127.0.0.1] with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Ping statistics for 127.0.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
post what happens. you can cut and paste from a dos command window by right clicking in the window title bar.
thx bill ....didnt know about the space in the command . But anyways my OS crashed completly , get one strange error message after another . Guess i have to clean the hdd and do a new install . Great ... :mad:
Gonna post after im done , maybe lan works again after that .
Hope mobo is not the problem because its gonna be hard to find a replacement .
You need to read my post in the Networking & Security forum (where this thread SHOULD be) regarding cable modem troubleshooting. You are likely having the same issue as the user in this thread is having.
Bottom Line: You need to reset the cable modem if you are going to swap devices out and you only pay for one IP address through your ISP. If (and only if) that doesn't fix the problem should you start doubting the hardware in your PC.
202276
thx much , strange thing is i always switched the network cable between my laptop and my main rig without turning the modem off and never had any trouble till now . I think you are right im in the wrong forum ... since i thought it was hardware related . Gonna follow your instructions and see what happends .
