Problems with Intel 850gb - "PXE-E61: Media Test Failure, Check Cable"
oneils
Hello, to start, I apologise for the long post, hope you guys can help though.
I'm having problems with a computer I rigged up for a friend. It was an old P4 1.8ghz machine that I upgraded with more ram, a new hard drive and windows xp.
She tripped over her power cord, unplugged the machine and when she plugged it back in, the computer failed to boot. She would get a blank screen with a blinking cursor, then would get a screen asking if she would like to start the computer normally or in safe mode. She tried each mode, but neither worked. She would only get a blank screen with a blinking cursor.
Well, I had a look at it yesterday and saw the same thing. Wouldn't boot into windows...one thing I noticed is that after choosing a configuration (safe mode or normal) the windows xp logo would come up with the progress bar. Just as the progress bar would get to the half way point, I would get a blank screen with blinking cursor.
Well, I tried to check out the BIOS after restarting (F12 on this machine) and I would get the following message:
PXE-M0F: Exiting Intel PXE-ROM.
Then it would just sit there until I restarted.
Well, I checked the optical drive and found it empty. I also made sure RAM was properly seated and that all connections were solid. Nothing seemed to fix it.
For kicks, I took out the hard drive loaded with windows XP. I then installed a hard drive with Windows ME already loaded onto it (I know...ewww Windows ME!). Behold! The computer booted to the desktop! It actually worked, i could get to the desktop.
One thing I noticed is that when booting, I did not see the VGA BIOS edition screen pop up, or the MOBO BIOS edition screen pop-up when booting with the windows me hard drive. Just a blank screen with a blinking cursor, then the Windows ME logo, then the desktop.
Any ideas what could be wrong?
Specs are:
Intel P4 1.8 GHZ
768 MB RDRAM
Intel i850GB motherboard
TNT 2 Ultra 64mb vga
Samsung dvdrw
Seagate 80gb ATA/100 7200rpm (xp drive)
Samsung spinpoint ATA/100 5400rpm (me drive)
Thanks for any assitance you guys can give.
Try booting without the ram you upgraded the computer with. Also Set in Bios to Reset All Configuration Data. See if that helps you boot into windows with the Xp drive.
Sound like the hard drive XP is on got corrupted, Or atleast it's MBR did. Which means the BIOS can't find a drive to boot from so it loads the LAN's boot rom and tries to boot that way, but the boot rom can't find a connection to a boot server. So it gives upi and hangs.
Go into your BIOS and turn off any network boot or LAN boot options you find. You may have to remove LAN or Network for the boot device list too. That'll get rid of the PXE stuff. As far as booting XP, you might try booting from an XP disc and starting the recovery console to see if it recognizes your XP install. If it does then run "fixmbr C:" and exit out of the RC.
Hey guys, thanks for the help.
I can't get into BIOS - all I get are those messages after pressing F12 on start-up. Basically, its a black screen with those messages.
I tried pressing the delete key as well...but that does nothing...no messages. No matter which drive is loaded (the xp or me one - sorry, in my first post I think I only mentioned that I could not get in bios with the xp drive loaded...but I can't get into BIOS period).
I'll try taking out the ethernet device and new ram (but that configuration worked fine for the last two months...).
Is there any other way to get into BIOS?
When I get back to my friend's house, I'll try getting into BIOS again and let it hang for a while at that message screen to see if I just had to wait a bit...
Again, thanks very much.
Usually if Delete isn't the key to get into BIOS, then it's sometimes F1, F2, F9, or F10, it's it's none of those, then hit every function key you see :)
Is this by chance a Dell computer?
Hi Ryan, thanks.
It's not a dell, its a computer made by a company called Seanix Technology. We use to see their computers in Futurehops up here in Canada. Most people would recognize them by the name on the case ....which was Cicero.
I'll try all the function keys and let you guys know how it works out.
Thanks, I really appreciate this.
if you just want to rewrite your MBR, boot off of the WinXP CD. Then go to the recovery/repair console or whatever it's called. At the prompt, type "FIXMBR" and it'll write you a new one.
Hi Kirbyri and others,
I can't boot off the Windows XP CD, tried that...but the system will only try to boot off the hard drive (I completely forgot to mention this). And I can't get into BIOS to change boot priority. LOL, I'm up shits creek. I'm going to try all the function keys in order to get into BIOS, when I get back to my friend's place.
Hi guys. Kirbyrj, I tried this out and it worked. The MBR was re-written and I was able to boot to windows. Before proceeding to desktop, though, the system did a "chkdisk". I'm guessing it was checking for errors. The chkdisk failed though. Then the system restarted and tried to perform it again...but I cancelled instead because I figured it would fail again. Then it proceeded to the desktop.
I'm wondering why this would fail? And, will the chkdisk occur on every boot-up until it succeeds? Other than this, everything with the system now seems fine. I'd like to thank everyone for their help.
Steph
- oh and I was able to get into BIOS by using F2 - thanks ryan for the tips.
It might be that your HDD has bad sectors or something like that. Go to the manufacturer site of whatever kind it is and download their utility .iso. Burn it to a CD and then boot off of that and do some diagnostic tests. Takes maybe an hour, but it'll tell you if your HDD is having problems.
Cool, thanks. Its a seagate. I'll try and diagnose it with their utility. Probably will have to wait - busy with christmas and crap. In the meantime, I'll be hunting for the receipt in case I have to call-in the warranty.
Again, thanks.
