Ok, I've got all piece, everythign was going fine maybe with little problem on and there but I could manage everything by reading... but right now i'm totally confuse about what to do. As this is the first time "i'm ordering every part and building it myself, I'm totally lost and ignorant about what's connection are for lol. Most part goes in and fit pretty well. but now, the power reste ect were a little troublesome ... but the real challenging problem is the fans and harddrive connection.
Mobo: Asrock Extreme4,
Case: Silverstone FT02
CPU: I7-3770k
CPU Cooler: Noctua D-14
PSU: Corsair Ax850
GPU: Asus gtx670
First off the Fans: The mobo has 3 chassic fans connection, 2x3pin 1x4pin, the case has 4 fan with 3pin connector, the 3pin connector are now near below the noctua. The 4pin connector is near the side fo the mobo. So how do i go about connecting 4x3pin connector to 2x3pin one?
The HD connection: Since the AX850 is modular, there alot of connection, but now if I want good cable management, to the ebst i can, it seem that the cable for the HD aren't long enough, so what to do?
Hope you guy can help me clear this out before i go crazy with this haha!
CPU: I7-3770k
PSU: Corsair Ax850
GPU: Asus gtx670
